Results 1 to 20 of 23
    Aug 2006
    Can someone confirm this that it is said if you accidentaly locked your car keys with the remote inside the car you can ask someone who is holding the spare remote in a different location or such as your house to disengage it via cellphone? Meaning you can make the frequency travel thru the cellphone? Is this true? I tested it with my alarm does not work some said works on other brand of alarms
    Jan 2008
    that would be cool if it's true!!
    Sep 2005
    that's it.. a myth.
    Aug 2005
    Sorry, not true. Just a Myth.
    myth.
    there's no way this can be true...
    Nov 2006
    i was a witness when my colleagues tried it. it did work with the given environment.
    what one of my colleague did was walk away from the car until he can't open his car anymore with the remote keys. he then called my other colleague and had him put his cellphone near the car's hood. it did not work when he placed the cellphone at the car's door, but it did work when it was placed near the hood.
    it was not really a controlled environment for me to say that this "truly" works. i am just giving an account of what happened, and maybe the distance that my colleague walk to is somewhere where the signal could be intermittent.
    let me try this myself and give another feedback.
    Aug 2004
    Quote Originally Posted by gerald_g View Post
    It could also be that the close proximity of the cellphone to the transmitter turned it into a booster antenna.
    For this myth to be proven, you have to do out of visual range. Simply, a cellphone will only transmit sound waves from the speaker... not radio waves. So, unfortunately, it's not possible.
    May 2005
    mas effective si inday papuntahin mo sa location ng locked car dala yung spare remote...
    Ano yan parang VoiceMail?
    :hihihi:
    hoax...
    Dec 2007
    oops, double post (darn Vista/Firefox... :-( )
    Jan 2008
    car remotes use radio signals. although, cellphones also use radio signals (since technically, a cellphone is actually a radio) but i believe its of a different (higher) frequency.
    its probably a myth.
    although, my officemates use their Palms' infrared to control TVs and aircons
    Aug 2007
    not true
    Dec 2007
    Quote Originally Posted by Cobalt Blue View Post
    Nag-post na ako ng tungkol sa hoax na yan:
    http://tsikot.yehey.com/forums/showt...28#post1038428
    Busted!
    5707:tumbleweed:
Car Alarm Myth
