everything in the alternator can be repaired or replaced. The rectifier and regulator are available in auto parts supply stores.
there are also carbon brushes inside which can be replaced.
But before replacing or starting to repair the alternator, checkfirst for corroded connectors or burnt wiring, this can save you a lot if the problem is just a corroded connector somewhere in the wiring harness.
