Results 1 to 8 of 8
May 3rd, 2017 10:53 AM #1
Dear sirs,
Where can i buy the ballast for a 2010 camry 2.4 v?
I had the bulb transferred to the other side and it worked thus ballast na daw problem.
Toyota is charging 11000 for the ballast alone. Anyone can point me to a source of ballast locally?
Bulb is D4S philips.
thank you
May 3rd, 2017 11:05 AM #2
Might be more worth it to get a branded aftermarket set.
Sent from my SM-G930F using Tsikot Forums mobile app
May 3rd, 2017 01:13 PM #4
Try mo check w/ garyq Of hid retrofit.net Maybe he can source a set for you
BANNED BANNED BANNED
- Jul 2013
- 421
May 6th, 2017 12:59 AM #511000 for a ballast? in yen? typo? let an electronic technician construct one for you. Or let him construct an electronic ballast.
mayb P50 lang ang parts.
- Aug 2012
- 2,767
May 6th, 2017 09:24 PM #6If OEM ballast yan, P11k should be for 2 pcs na. If aftermarket ballast naman, P3k to P6k will get you 2 pcs depending on brand. So that will be P1500 to P3000 per ballast.
You can check prices here:
The Retrofit Source | The Best HID & LED Projector Headlight Upgrades
Sent from my ASUS_Z010D using Tapatalk
- Jun 2005
- 3,774
May 6th, 2017 10:30 PM #7Xenon concepts do projector retrofits for 10k.
You might be able to use their ballast for a fraction of the cost, or you might want to change the projectors instead.
Replacement is still cheaper by 1k compared to 1 pc ballast
- Aug 2012
- 2,767
May 6th, 2017 10:39 PM #8This site sells OEM ballast D4S for Toyota Camry. Buy 1 pc if you just need 1 pc.
Toyota Camry Aurion Altis Headlight Issues OEM HID Ballast Bulb Replacement
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
