Results 1 to 8 of 8
    Mar 2005
    Dear sirs,
    Where can i buy the ballast for a 2010 camry 2.4 v?
    I had the bulb transferred to the other side and it worked thus ballast na daw problem.
    Toyota is charging 11000 for the ballast alone. Anyone can point me to a source of ballast locally?
    Bulb is D4S philips.
    thank you
    Might be more worth it to get a branded aftermarket set.
    Sent from my SM-G930F using Tsikot Forums mobile app
    Mar 2005
    Quote Originally Posted by ssaloon View Post
    Any suggestions on brand and where?
    Try mo check w/ garyq Of hid retrofit.net Maybe he can source a set for you
    Jul 2013
    11000 for a ballast? in yen? typo? let an electronic technician construct one for you. Or let him construct an electronic ballast.
    mayb P50 lang ang parts.
    Aug 2012
    If OEM ballast yan, P11k should be for 2 pcs na. If aftermarket ballast naman, P3k to P6k will get you 2 pcs depending on brand. So that will be P1500 to P3000 per ballast.
    You can check prices here:
    The Retrofit Source | The Best HID & LED Projector Headlight Upgrades
    Sent from my ASUS_Z010D using Tapatalk
    Jun 2005
    Xenon concepts do projector retrofits for 10k.
    You might be able to use their ballast for a fraction of the cost, or you might want to change the projectors instead.
    Replacement is still cheaper by 1k compared to 1 pc ballast
    Aug 2012
    This site sells OEM ballast D4S for Toyota Camry. Buy 1 pc if you just need 1 pc.
    Toyota Camry Aurion Altis Headlight Issues OEM HID Ballast Bulb Replacement
camry HID ballast help
