Results 1 to 2 of 2
- Nov 2009
- 21
November 24th, 2009 10:35 PM #1Good day!
2005 Nissan Sentra GX 1.3L A/T
Parked vehicle gone underwater with the battery dying on it. Moved it to CASA for repair and so far these are the parts that they found damaged.
A/C Blower
Instrument Panel
Power Window Switch (all doors)
Spiral Cable
Resistor Block
(all of these costs a staggering P100k plus already plus the labor)
Can these parts still be repaired? CASA don't repair damaged parts, they freaking tell you to replace it! Where can I have these parts repaired for a reasonable price?
I'm also willing to buy a 'surplus' for these parts, but where? My last option is...well CASA.
Vehicle's engine already running, the car not yet. It's under observation (daw), so I guess the ECU is fine, I'm just hoping that the Transmission module is OK as well. Please help because I don't have such amount to spend. If it goes beyond 150k then I might as well buy another 2nd hand car.
December 22nd, 2009 09:41 PM #2
A/C Blower Buy a surpluss nalang there are also replacement but original is still the best
Instrument Panel. There are some can repair but I think you will end up where you started. Such as in kitanlad st in Banawe had mine repaired before.
If you're lucky you might get a simmilar one problem is Japan surplus is different sometimes from local
Power Window Switch (all doors) you can get this easily
Spiral Cable
Resistor Block
Goodluck!
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
