Results 1 to 7 of 7
    Mar 2013
    I scanned my friend's civic with P0336 code (Crankshaft position sensor). Nag stall na during long drive at kumakadyot paminsan minsan.
    Ano pinakamagandang solusyon dito mga tsong?
    Aug 2012
    Quote Originally Posted by johncoder View Post
    First know to locate where that sensor is mounted, then dismount it to check and inspect. Check and inspect its wire connectors, it might be loose in its socket connection. Before deciding to buy that part, or replacing it. Try cleaning it first from any carbon or dirt build up. And never forget to disconnect the battery negative terminal first before working on these procedures or when dismounting the sensor.
    Starmobile Up+
    Mar 2013
    salamat sirs!
    Dec 2008
    My Honda 2005 CRV/RD7 2.4 x 4 AT has been showing engine light trouble now and then for past years. Engine loses power but can still be driven. I just turn off then turn on to return to normal. But it comes back often. A friend used an OBD and showed a Throttle Positioning System (TPS) error. I bought a replacement from Amazon. Part No. 977-022. This week, I brought the car to a Honda Service center but was advised that they cannot replace the part. They claim that they cannot adjust something and that it might worsen if they try to replace it. Does anybody have an idea as to how this TPS is replaced or probably a recommendation of a service center who have experts on this matter. Thanks!
    ^ you can try speedyfix in pasig. they're pretty competent when it comes to honda maintenance and repairs
    Speedyfix is in San Juan, along P. Guevarra
P0336 error code Honda Civic 2006
