Results 1 to 4 of 4
- Jul 2017
- 1
July 28th, 2017 07:52 PM #1Sir ano kaya problema nitong motor ko wlang kuryente yung wire ng headlight
Sent from my Q894 using Tapatalk
- 54,289
July 29th, 2017 12:51 AM #2
- May 2011
- 481
July 31st, 2017 01:07 PM #4
the way i understand it, the vehicle in question is perhaps a motorcycle? there has to be problem with the fuse, the headlight, the switch, grounding or the conductors both the power side and the ground side. if you don't have the tools to do diagnosis, you can substitute with known good light bulb, or connecting an alternate graund wire, or if it does not respond, try connecting an alternate power supply wire
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
