Results 1 to 6 of 6
    May 2016
    Pag naka turn on kasi ang lights okay naman lahat working.
    Pero pag nagbrake na may isang bulb na hindi gumagana.
    Then pag nag bright naman nawawala naman ung isang ilaw sa isang side. May problema kaya to sa electrical? Or sa bulb lang to?
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Quote Originally Posted by Sedanlover View Post
    malamang po, ay pundido ang isang filament ng double filament bulb ninyo.
    puede ring madumi o may sira ang bulb socket contacts.
    May 2016
    Akala ko major problem na. Thanks Dr.d
    Jun 2012
    Kung walang kumalikot, maaring bulbs lang yan.
    Feb 2009
    On the weak light, measure the voltage across the two terminals of the light bulb,. The voltage should be no less than 0.5 volts lower than the source voltage. If it's not , you have high resistance somewhere. Identify your car
    May 2016
    Lancer cedia 3rd gen po
Brake lights and bright lights
