Results 411 to 414 of 414
- Apr 2010
- 742
February 25th, 2025 12:35 PM #411Search for "battery tray" and "battery hold down" na lang sa LZD Racing or SHP Motosports
Sa Innova 2KD I've only used that battery tray, since the stock hold down works naman for both 2SM and 3SM
Sa NP300 no need to change anything from 2SM to 3SM
Aside from the longer lifespan, the starter sounds a lot better, parang gigil lagi mag start lol
Mukhang possible... ito mga nahanap ko sa Youtube so far:
Toyota innova 2019 change battery DIn66 origin convert to 2sm
Toyota Hilux 2023 | 2SM Amaron | DIY Battery Replacement | Battery Bracket Replacement Fit 2SM & 3SM
3sm Battery fit sa Toyota Innova 2017 to present
Toyota Innova 2023 Model Battery Replacement from Motolite gold to Amaron Pro
- Feb 2014
- 2,712
February 25th, 2025 01:32 PM #412
got it as backup coz it's dry charged i.e. can be stored w/o degradation. but i accidentally pulled the seal so i had to activate it LOL
P19xx shipped (lazada)
i like this style of batt coz translucent case makes it easy to check levels. but the plates on this cheap batt aren't full height so the CCA is a paltry 250 (may increase w/ use, batt makers specifically warn that digital batt checkers may not give accurate results w/ newly activated batts)
- Jun 2011
- 1,240
February 25th, 2025 07:53 PM #413Ay oo kita ko din iyan sa Lazada. 1988 from batteryexpressph. Worry ko lang kung maayos delivery. Buti nakarating ng maayos diyan.
Based sa comments dito kahit MF kailangan din ng distilled water top up. Kaya might as well buy iyong may ready caps/access.
Na try naman namin OEM LM battery from Indonesia na umabot ng 3+ years. Though mostly highway driven.
Itong recent LM OEM batt, 2 years lang, halos short trips lang.
- Nov 2017
- 291
May 15th, 2025 09:51 AM #414
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to turn it off) umabot ng 3 years and 8 months . Ok pa naman battery life which is about 55% and pwede pa for another 4 months + but I decided to replace since your starting to feel it from cold start.
I put AC Delco with i-stop, 24 months warranty.
VinFast VF 3
