Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 423
    I left my car for a month without starting and it was working perfectly still with Amaron battery.
    I would have to say Amaron since ito pa lang na test ko.
    No complains from me also. Malakas pa rin redondo even after a year of use. Unlike motolite, after a year you could hear na mas mahina na.
    Dec 2009
    more than 32 months na yung amaron ko... it has been discharged more than 4 times (less than 10 volts) dahil sa nakakalimutan off interior lights, etc....
    so far so good, no change in performance and starting power...
    ito na pinaka matagal na battery life so far na nagamit koh.
    i hope tumagal ng 60 months.. hahaha...
    May 2009
    Quote Originally Posted by miko101130 View Post
    Hope it does coz my motolite gold 3 SM discharge 3x lasted for 5 yrs and 3 months
    Oct 2009
    for me panasonic. tested na yan sa suv at sa sedan namin. mas mura pa meron kasi sila sa libis kaysa tatakbo pako ng banawe if youre from that area.
    May 2009
    My car's battery is more than 3 yrs old now (stock). I am thinking of replacing it and I cannot decide between Amaron or Panasonic.
    1SN for Amaron is P3.5k and Panasonic is P3.2k but with shorter warranty. My stock battery is Thailand and I am very impressed that it lasted so long! The dealer said Panasonic is also Thailand so I am thinking if Panasonic is better though it is cheaper?
    My motolite gold 3 SM fitted on a starex lasted for 5 yrs and 3 months.
    Mar 2013
    Sign na malapit kana magpalit ng battery. once you turn key to start at maypause or slow crank ang engine (delayed reaction ba) from there may 2 to 3 months kapa bago tumirik hehe assuming malinis terminal and relay ng starter. By this time tapos na warranty ng battery im sure. pwede mo na remove ung label sa top portion ng battery (any brand na no maintenance free kuno) visual na ung 6 refill caps once u open makikita mo na malaki kulang or baka wala ng tubig, add ka na lang. by adding distilled water or tap water sa neck level 6 months or more ang lifespan pa niya. Kung maingat ka after ng warranty add kana kagad masmaganda.
    Quote Originally Posted by joey36b View Post
    may kilala ako.
    palit siya ng battery every 2 years, regardless.
    ayaw na niyang ma-hassle ng failing battery syndrome.
    automatic ang car niya.
    Mar 2013
    may kilala ako.
    Yan ang tama doc. Hehe maslalo na pag-girl driver unang sign palang or 2yrs. Na battery replace na kagad.
    Mar 2004
    may kilala ako.
    This is somewhat a good idea ... planning to do this ...
    i... wait until my battery dies. quripot talaga...
    motolite delivery is so convenient, if one doesn't mind waiting a bit.
    Mar 2013
    ... mas-kuripot ata ung nagdadagdag ngtubig sa no maintenance battery hahaha
    de tubig(2sm) yung OEM ng pickup ko, alaga ko sa check/dagdag ng distilled water.
    on it's 3rd year nakaranas ako minsan ng hesitation to crank na wala naman dati. my volt meter reads 12.1v then drops to 11.x when i turn the key to ignition. pinalitan ko na agad at baka abutin pa ako sa daan.
    Mar 2013
    Quote Originally Posted by benchman View Post
    Un nga un sir palit na kagad, pagdiesel malakas sa tubig kaya nagffail ung battry kagad pagkulang. 3yrs na battry sulit na din at sa dieael pa. masnagulat lang ako sa iba 5yrs ok pa eh sobra sulit na hehe
    bro yung de tubig mo ba na batt, every week or every month ang check mo ng water level? also, ilan KM travelled dun sa 3 years?
    once a month ako nag-check nun, dalawang beses lang yata ako nag-top up bago sya mapalitan.
    ~20k odo reading.
    ~20k odo reading.
    Not bad, usually 40-50% ang LM batt diba?
    Sent from my D5303 using Tapatalk
    Mar 2013
    Kung gas engine every 3 to 4 months ang refill, pagdiesel every month.
    bad trip, plano ko sana i refill yun "no maintenance" 3k battery ko after 15 mos warranty lapse (june 2017). kaso pag silip ko sticker, walang pag rerefill-an. sino may alam pano baklakasin yung top cover?
    Mar 2013
    Dko kabisado 3k battery, pero hindi mawwalang ng refill plugs yan. Remove mo lang buong sticker sa ibabaw. malamang sir yan ung buo na takip na pang 3 butas. Try mo angat sa gilid ng tip na screwdriver.
