Results 11 to 15 of 15
August 26th, 2011 10:17 AM #11
Pag grounding po ang problema, wala po kayung papalitan, additional wires po ang kelangan nyo idagdag sa grounding, for better result po, if not the battery is the problem, upgrade this whole thing to big three, by these way, wala na po kayung magiging problema like bad charging or headlight dimming, also hard starting or start fail will be eliminated. Read more here http://tsikot.com/forums/car-audio-v...upgrade-79384/. Dalawa lang po ang nakikita kong problem dito sir, una yung battery post maybe brocken kase kapag ginagalaw nyo yung post nag iistart naman, pangalawa po is bad grounding na nga, pa check nyo na lang po agad..
- Aug 2006
- 98
August 26th, 2011 01:32 PM #12
Sir X-isle, I assume na bumababa din ang rpm mo everytime you open up your headlights, right? My problem is...nagda-drop rpm ko from 900 to 700 pag naka-on ang HL.
Im also having almost the same issue, pero ang sakin ay negative terminal ng battery at un wire lang ang umiinit...the positive side is not...my battery is exactly a year old this month, motolite enduro 2SM.
Pinacheck ko na ang battery at alternator ko in a motolite shop nearby at kumakarga naman ng maayos pareho at walang nakitang problema with those 2.
Hinde ko pa din kasi napapatroubleshoot ng husto un auto since wala pang makitang trusted at reliable electrician sa bago namin nalipatang lugar. TIA
August 27th, 2011 11:23 PM #14
- Sep 2009
- 24
August 30th, 2011 05:40 PM #15you must also check your alternator/regulator with a digitester, kung wala hanap ka meron tulad sa motolite, dapat hindi lalagpas ng 14volts yung tester pag nilagay mo sa battery at pag umaandar at naka rev, baka nag o over voltage kaya umiinit yung baterya sinyales na sira yung regulator.
I received this email from Fleetguard Understanding coolant and recommendations I think this...
