Results 11 to 20 of 22
- 10,620
March 23rd, 2007 03:08 PM #11check all....
battery, batt terminal, batt cable, starter, carbon brushes
- Dec 2006
- 32
March 23rd, 2007 03:34 PM #12
- Jun 2006
- 1
March 23rd, 2007 07:17 PM #13Nangyari din sakin to Last Monday, ang aga kong umalis ng bahay tapos ala 1KM natakbo ko, medyo traffic kc eh, namantay ang makina tapos try ko start 2-3 times kaso ayaw mag start, kala ko sa high tension wire or spark plug, try ko galaw-galawin ung high tension wire tapos, try ko start ulit, kaso ayaw pa rin mag start, din tawag ako ng mikaniko, eh nasa gitna pa naman ako ng kalsada, biglang haba ng traffic, mga after 20 minutes nag try ulit akong mag start ng engine, tapos ayon, nag start din. may napansin akong wire sa battery terminal ng ground pa punta sa engine body, mukhang maluwag nga kc i'm planning to replace a terminal lug for that. buti nalang nakita ko d2 sa thread na to problem ng auto ko.
check ko bukas wiring.
happy weekend
- May 2006
- 141
April 25th, 2007 09:28 AM #14
- Jun 2006
- 86
April 28th, 2007 06:11 PM #15ganyan din saakin.. click lang minsan. pero yung saakin naman, it has something to do with the fuel pump. kelangan ina antay ko yung bomba ng fuel pump matapos before ko i start. napansin ko kasi na kapag start ko while bumo bomba ng fuel, nag cli click lang..
yung sa corolla namin, ganyan din.. yun nga.. yung grounding and batter terminal. pinalitan ng de pihit rather than de-screw.. yung ground, bumili kami ng grounding kit. 1k lang naman yun..
April 28th, 2007 10:40 PM #16
I'm having this exact same problem right now.
I stop the car at the house, then when I go to start it, it won't start, It just clicks. So, I get a jumper and have my car battery jumped. Yan, ayos na. I went to Tagaytay, ok na ok. I went home and parked the car outside the house. WHen I went to start the car to bring it in the garage, I just hear click lang.
I cleaned my terminals. But, after I jump it, it works. So, what's the problem with my car? I'm taking it to my uncle's place tomorrow to have it checked out. I guess I can rule out the starter, so, it might be the battery and wirings? This all started after I took it to Rapide by the way....a week later.
I know they screwed around with my wiring..because my speakers turn off when I hit bumps.
April 28th, 2007 11:03 PM #17
Better check your wirings din, madali lang naman yun minutes lang di kapapawisan kailangan mo lang ng tester
share ko lang yung nangyari sa pick up ko akala namin battery kasi luma na din pero nung pinalitan ng bago after some days ayaw na mag start yun pala yung connection lang ng alternator ang naputol kaya di nakakargahan yung battery
April 28th, 2007 11:05 PM #18
same issue here. un lancer 79 ko. usually quick start lang sha, pero after ma-stock at hindi magamit un car for several days, yan na. kanina ko lang din naexperience na hindi na magstart and long cranking sound lang.tinulak ko nagstart naman agad makina. nun pinatay ko uli nagstart din naman agad, pero later tonight nun papaalis nako, yaw na uli magstart! my bad is, kulang sa rev kanina nun nagstart na. i think it's more on the batt, baka nadischarge ng kaunti kaya mahina cranking power to start up the engine.
normally kasi, mga 13V plus ang kelangan ng makina to start. pag lower, di talaga kaya. im sure pag jimumper ko tomorrow yun, aandar agad un. hope di pa sira batt ko at wag na sana iparecharge, madaan lang sana sa rev
moral of the story, laging gamitin ang oto, kung di man, painitan ang makina every day.
April 28th, 2007 11:14 PM #19
April 29th, 2007 12:21 AM #20
If its non reduction starter solenoid switch.
If reduction, bendix drive.
If you think battery connection or ground connection, pour some water on that part to improve transfer of electricity
For reliable and affordable car service in Metro Manila, I recommend Speedlab. They have competent...
Wheel Alignment
