Results 1 to 10 of 10
    Sep 2010
    What could be the problem? The battery Sign does not light anymore when i put it to "ON" without starting the engine...
    All the other lights are ok... i just had it cleaned few weeks ago and replaced all the bulbs... is there a fuse for this?
    replace the bulb for the battery indicator. Or maybe the bulb was not connected properly.
  3. #3
    bka may natangal lang na wire.. anu model year ng car?
    Feb 2009
    Quote Originally Posted by batusai_jr View Post
    your voltage regulator or its charge warning circuit in it has gone bad. this should be accompanied by a charging system malfunction
    Sep 2010
    Quote Originally Posted by mazingerZ View Post
    newly replaced yung bulbs eh, loose connection maybe? but i dont know how to DIY it
    Quote Originally Posted by alwayz_yummy View Post
    always yummy and jick -
    Is there a wire connected to the battery? thats the only thing that has been removed few weeks after the bulbs had been replaced... the battery cables has been removed about a week ago...
    Jun 2010
    you mean sir nagpalit ka ng gauges bulbs? baka nabaliktad nyo lang yun polarity ng bulb, baliktarin nyo lng
    Sep 2010
    Quote Originally Posted by ReXBadBoy View Post
    yup pinapalitan ko sa banawe nung ipinalinis ko yun kasi medyo malabo na, gumagana naman siya, napansin ko lang nung ipinaayos ko yung compressor, may nakatanggal na bakal sa baterya, inilagay ko kasi dati yun kasi maluwag, e after nun ok naman, tapos after few days bigla nagblink yung mga ilaw ng gauges, tapos ok naman, after 2-3 days napansin ko hindi na umiilaw yung battery sign nung nag ON ako ng switch
    get it checked na lang sa suki mong electrician , baka ma low batt car mo at itirik ka pa.
Battery Sign on the Dashboard (doesn't light up)
