Results 1 to 18 of 18
    Jun 2017
    Help po, may battery kami Motolite Gold. 2 years na pero minsan lang nagagamit, pinapaandar lang sasakyan every 1 week tapos tinatanggal yung positive side after. .then nasiraan kami alternator pumutok diode ayaw magcharge. .then nung naayos na alternator nagchacjarge na battery, reading ay 13.1 v right after tanggalin yung positive side. .pagkabukas nagdodrop na to 10.5 volts pero nakakastart pa sya, cranking volts at 7.4v. Bakit kaya nasira battery eh minsan lang naman nagagamit yung sasakyan? Any inputs or suggestions sa experts jan?
    Jun 2015
    How long is it driven when it is driven? Starting the engine ang pinakamalakas maka-drain ng baterya. Kung short trips ka pa lagi, hindi na narerecover yung nawalang charge from starting up the car. So you end up with a battery that is always partially charged. Pag partially charged ang battery, nagkakaroon ng crystallization sa charging plates. In other words, nagde-degrade. Pag hindi na maayos ang plates, hindi na magho-hold ng charge ang baterya mo.
    Covered garage ba? Kung mainit dahil parating bilad sa araw, may negative effect din sa battery.
    Sent from my Nokia 6.1 using Tapatalk
    Batteries dont normally last that long. Just look at the warranty lengths offered by amarok motolite.
    Quote Originally Posted by mckeinley View Post
    1. old age.
    2. prolonged state of discharge. madalang gamitin. at kapag ginamit naman, hindi lubos ang pagka-charge bago patayin muli. the battery plates deteriorate faster, if they are kept in long periods of un-fully-charged state.
    and padagdag:
    mal-functioning charging system (i.e., alternator).
    May 2017
    just be sure the alternator is 100% fixed
    Sep 2005
    baka nadiskarga kasi minsan lang gamitin.. dapat sa battery na cha charge.. kung pa start start lang hindi mag cha charge yan..
    try mo pa charge sa battery shop.
    Mar 2017
    will using a smaller battery size affect your car?
    called motolite and it recommended a smaller size battery for my car (didn;t know until they delivered it).
    when the installer saw it, he said it's ok to install and it wont affect the engine.
    having doubts about this
    Quote Originally Posted by xnxnxn View Post
    Shorter expected service life....which can be a good thing if it goes before warranty's up.[emoji4]
    May 2019
    Ay speaking Sir Qwerty.. May tanong pala ako about battery.. Last December kasi pinatay ko makina pero iniwan ko naka hazard yung kotse ko.. kasi naka-park ako sa tapat nung isanhg store na wala na sila enough parking for their customers.. so inakyat ko kalahati ng kotse sa may gutter / drainage..
    Nag hazzard ako para iwasan or mapansin ng ibang driver.. Tapos mga 30mins siguro ako dun sa store, 30 mins nagha hazzard kotse.. Nakakasira ba ng battery yun kapag laging gagawin?
    Huwag mo na problemahin yan kahit hinde mo gawin yan, papalitan ko pa rin battery pag nasira since it's consumable part.
    Mar 2017
    ok so hopefully no problem whatsoever with the car engine
    Feb 2020
    Answer: Possibly, there was an internal short circuit in the vehicle's wirings esp. in the diode or rectification circuit of the alternator that has drained the battery and that can occur even if the ignition switch has been turned off.
    If natanggal yung (+) or (-) post pagkatapos mag-chargr, yung 13.1V terminal voltage ay hindi ibig sabihin na fully charged na battery.
    Critical parameters yung rating ng alternator charging current and voltage sa capacity i.e. AH ng battery pati. Mallit battery pero high cap naman altrenator, baka sumobra initial charging current pag nadiskarga husto baterya - grabe sigurado init nun o pag mahina klase, mag-alsahan mga vented cell covers ��
    May 2017
    Well possible rin na matagal nang may problema ang Diode mo, and because of that, the electricity AC was not being converted enough into DC by your faulty alternator. Too much AC can really destroy your car battery
    May 2017
    Quote Originally Posted by DreamTracker View Post
    haha tama, yan ang ginawa namin sa Suzuki Swift ng father ko, mas maliit yung battery na binili namin to what is required size kaya makikita sa battery analyzer gadget na mabilis na siyang uminit (mas mataas ang internal resistance test na lumalabas sa test result)
    batteries deteriorate over time. no exceptions. lalo na kung hindi ginagamit at pa-start-start lang paminsan-minsan.
    siguro, mas tumagal pa yan kung ginamit ninyo sa long trips.
    Jun 2015
    Anyone has unused / drained 1SN battery? I need one for a project. I'll buy it from you. DM me if you want to sell your unused batt. Thanks!
    May 2019
    Oo nga naman.. Di ko na iisipin yan sayang space sa brain cells ko.. Mai-recycle bin na..
    Mar 2020
    Thanks for the info
Battery problem
