Results 1 to 14 of 14
    Apr 2014
    I bought a new Panasonic maintenance free 2sm battery .. Is it already pre-charge or do I need to have it charge first before installing to the car ???
    If its pre-charge, how many percent of charge does it have ??
    Aug 2015
    Quote Originally Posted by Dezaremos View Post
    It is already pre-charged and ready to use.
    Start your engine upon installation and let the engine run for several minutes to full charged it.
    sent from my Nokia 3210i
    Aug 2012
    Use a digital voltmeter to measure battery voltage. Refer to chart below.
    Just use your car like you normally do. The alternator will charge the battery during your trip.
    Sent from my D5833 using Tapatalk
    Aug 2012
    To monitor battery charge, I use this inside the car.
    Engine off.
    Engine on. Battery charging.
    nakita ko nga iyang battery monitor next ko bibilhin iyan
    Aug 2015
    Quote Originally Posted by red_one View Post
    Engine off.
    Medio mababa output ng alternator mo sir, 14+ ang usual.
    May 2009
    Quote Originally Posted by Mentis View Post
    mataas pa rin iyan.
    Aug 2012
    Nagbabago reading nyan brod.
    Quote Originally Posted by miked View Post
    mataas pa rin iyan.
    Yup. 14.7 and up will cause your battery to leak acid! 14.5 is the optimum level.
    Aug 2012
    Guys, may date code ba ang Motolite battery? Is this "021712" the manufacturing date or not? Battery is Motolite Gold.
    Feb 2009
    System voltage with engine running varies with different makes. Don't be surprised if your Toyota runs 15.1 volts with engine running. Most newer car voltage regulators are inside the pcm and are pulse width modulated. Maintenance free or recombinant batteries were designed not to reach full charge condition to reduce the water loss when they are hydrating during the charging process.
    Feb 2017
    nice info! pero alarming ang 15volts while running
    May 2017
    constant ba ang 15v? not fluctuating..paganun baka magacid ang battery mo.. 15v is overcharging already.. giving your battery a shorter life..=) ( 3 posts pa =\ )
    Aug 2017
    brod ano po tawag dyan? Salamat po. Bibili din Sana ako.
New Battery ????
