Results 1 to 6 of 6
- Nov 2004
- 45
November 17th, 2011 02:57 PM #1Pa recommend naman on how to fix and where preferrably south area.
My ride is an Altis auto. 2003 with an airbag
Previously sometimes the horn will function and not function.
Yesterday it has no sound at all up until today.
thanks
November 17th, 2011 08:30 PM #2
remove the terminal socket from your horn, kuha ka ng electrical wire, try mo iderekta sa battery kung ok naman siya at tumutunog, baka yung wiring ang may deffect
- Jun 2005
- 3,762
November 18th, 2011 10:15 AM #4
check mo yung wirings..baka nag loose lang or poor contacts, liyahin mo yung mga terminals..
February 14th, 2012 02:06 PM #5
sir baka po yung clock spring sa likod ng steering wheel ang may problem para po syang ribbon wire dun po dumadaan lahat ng kuryente papuntang manibela, horn, airbag trigger, etc.
February 14th, 2012 04:22 PM #6
check your fuses first. then, check if there is sufficient ground and power to the horn connectors. measure the voltage across the negative and positive terminals. specially, do not probe, jumper or disconnect the wires that are color coded yellow or harnesses color coded yellow lest your airbag deploys unintentionally unless the srs or airbag system had been disarmed. follow service precautions to avoid accidental deployment, damage to the vehicle or injury to yourself.Last edited by jick.cejoco; February 14th, 2012 at 04:24 PM.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
