Results 1 to 10 of 11
- May 2011
- 10
May 22nd, 2011 10:14 PM #1please help me with my tamawar fx. ayaw magcharge ng batteries. bumili ako ng bago thinking na dead cells na pero after using for one day e ayaw nanamang mag charge. may clicking sound pag nagstart ako. i remember the last time na ok na nag off ung radio ko after releasing the gas, pero mag on ulit pag nag step na ako. and oh, busted ung fuses ko sa headlights....
May 22nd, 2011 10:21 PM #3
kung tama pagkakaintidi ko, namatay yung radio at low rpm and then nabuhay uli nung magaccelerate ka... usually, the first diagnosis would be battery or alternator ang problem (charging system)
since bago yung battery mo, check mo muna yung alternator and regulator... then post mo kung ano status nila... baka kasi wiring lang ang problem since busted yung fuse ng HL...
- May 2011
- 10
May 22nd, 2011 10:39 PM #4pag grounded ba ung wyrs ng HL ko un din ang cause ng hindi pagcharge ng batts?
- May 2011
- 10
May 22nd, 2011 10:41 PM #5ok, will do that tomorrow. hindi ko lang alam kung pano magcheck ng alternator. try ko sa youtube. tnx for the reply po. pag tama Dx mo, bigyan kita starwberries pag napagawi ka sa baguio. GOD BLESS
May 22nd, 2011 11:03 PM #6
- May 2011
- 10
May 22nd, 2011 11:28 PM #8
if the question is kung hindi mag charge, it depends....
pag ang grounded ay yung load after the fuse na nabusted, dapat mag charge na siya kasi wala na continuity sa faulty wiring...
pag ang grounded naman ay before the fuse (not the main line fuse), mag charge pa rin siya kung di naman directly in contact sa negative side (body) yung live wire (+) since, technically, the fault will be considered as a mere load (resistance). yung nga lang, ma discharge yung battery mo agad just like DF said...
on the other hand, pag total contact (0 resistance) ang scenario ng grounding, dapat ma detect mo agad yung problem since most oftentimes ay maging visible siya (for sure kasi mag melt yung wire or meron spark) unless mag cut-off yung main fuse.
- Jan 2005
- 445
May 23rd, 2011 07:43 PM #10
nakailaw ba sa dashboard ang batt, pagnakailaw ito meron kang problem sa alternator (not charging) pag wala grounded kaya na drain ang battery
