Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jul 2003
    anyone using auto gauge? effective ba? where nyo nabili and how much ?
    Jan 1970
    i'm using auto gauge tach accurate and has 7 seven colors. bought it in karplus
    Feb 2003
    since were talkin abt autogauge, may question din ako.. my ride is a stock hatch, ph12 pa din engine ko.. parang ang hirap umakyat ng rpm, la kasi ako alam pg carb eh, ganun ba talaga un? first time ko kc sa carb type.. dati lancer ride ko, efi.. ung normal na tapak ko sa gas sa lancer, rpm ko is 2.5-3.5.. pero sa hatch mabigat pa din paa ko sa gas pero hangang 1-1.5 lng rpm ko, normal ba un sa stock hatch o may problem tach ko? thanx in advans peeps..
    Jan 1970
    naka auto gauge ka din na tach? baka nasa v12 ung selector nya sa likod?
    Jan 1970
    dapat na sa 4 lang, stands for the number of cylinders.
    Feb 2003
    yup.. it's an autogauge, how do I adjust or check that V12 selector? is it at the back of the tach? thanx..
    Feb 2003
    kakahiya kc minsan pg may sakay ako.. sobrang hataw na hataw na ako tapos rpm ko nsa 1.5-2 lang.. todo gigil na makina ko nun ah..
    Feb 2003
    peeps, help naman, san ba mkikita ung selector? sa likod ng autogauge tach? wala nman ako nkakapa eh.. o bubuksan pa dpat ung tach? thanx..
    Jan 1970
    lahat ng auto guage (3"-5") meron selector sa likod (katabi ng wire) 4, 6, 8 = this stands for the number of cylinder.
    check also the grounding wires.
    Question: how does Autoguage tach gets its reading on the engine's RPM? Does it tap to the stock tach or where?
    I'm just curious if such tachometers can be installed into the new Toyota VIOS since its stock tach is digital LED.
    Feb 2003
    ryan: san dpat nkaset un pg stock hatch? sa 4? madali lng ba makita ung selector na un? thanx..
    Feb 2003
    ei peeps, tiningnan ko likod ng tach.. wala naman ako nkitang selector.. lahat ba ng autogauge meron nun??
    Jan 1970
    sir yung 3" & 5" auto gauge tach ko meron selector (4,6,8) kung na ka inline 4 ka dapat na sa 4 din.
    sir ghost, sa distributor.
    Jan 1970
    beintedos, pare ganyan den problema sa tach ko, sinet ko lang ng "4" sa likod ok na. but am not really sure if its accurate though. halos lahat ata ng tach ng auto guage has that switch sa likod, am using a 2.5" (or 3" inch tach) mounted sa likod ng steering wheel a little forward from the dash, pati ganon kaliit na tach meron switch.
    Jan 1970
    basta njan lang sa likod yan madali lang makita
    Feb 2003
    yep, kita ko na.. thanx peeps.. engine ko is ph12 lng.. sinet ko lang sa 4.. it seems ok na! thnx again peeps..
    guys magkano ba ngayon ang autogauge tach na 5' jan ngayon?
    grabe mahal dito almost £200 then meron pang brand na splitfire pero mukha ng autogauge lang!!!
    Feb 2003
    5.5k ung kuha ko sken..
    ako nasa 6k carbon fiber kasi ung akin eh..
    Aug 2003
    ghost,
    im using a autogauge monster tach, yung reading ng rpm na ka tap sa positive line ng distributor.
Auto Gauge
