Results 1 to 10 of 13
- Dec 2007
- 16
December 10th, 2007 06:03 PM #1Kano po kung magpapalit ako ng tension wire for honda civic model 98 including labor? at san po maganda magpapalit balak ko sana s speedyfix? Thanks po s mga magrereply.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 11th, 2007 08:06 AM #2why replace it? wala din power gains even if you do. only replace them kapag may sira na sya.
December 11th, 2007 08:54 AM #3
it depends sa brand pag splitfire mas mahal mga 3k ata, sa banawe marami 1.5k-2k pag mga di kilala na brand. napansin ko nga din nagpalit ako ng high tension wire, 5star yung brand 9.5mm parang wala naman nagbago sa takbo ng civic ko. nag-iba lang mas gumanda tingnan kasi color yellow..
- Dec 2007
- 16
December 11th, 2007 11:51 AM #5Sira n yung first cable ng tension wire tumatalon n yung kuryente kaya gusto ko n palitan... at sk balak ko rin magpaayos ng idling... Need ko malaman yung presyo para alam ko kung magkano aabutin para pagpunta ko dyan s inyo mr speedyfix maayos n lahat ng sira... Thanks
December 11th, 2007 02:25 PM #6
sir, sa classified ng tsikot may binebenta na high tension wire under accessories section, 1.2k made in usa 10.9mm.. check out this link http://tsikot.yehey.com/classifieds/...ct/6362/cat/47
yung pagkabit kahit ikaw na mag ang install madali lang naman yan.
December 11th, 2007 03:06 PM #7
Don't use cheap wires. Either get OEM wires or higher-priced ones. The cheap Chinese wires have rubber boots that crack after just a few thousand kilometers.
- Dec 2007
- 16
December 11th, 2007 03:46 PM #8
December 11th, 2007 04:08 PM #9
OEM... straight from Honda. Costs more, but will last longer. Or you can specify Honda-branded wires.
- Dec 2007
- 16
December 11th, 2007 05:29 PM #10
Latest mileage:
