Results 1 to 13 of 13
    Dec 2007
    Kano po kung magpapalit ako ng tension wire for honda civic model 98 including labor? at san po maganda magpapalit balak ko sana s speedyfix? Thanks po s mga magrereply.
    Nov 2003
    why replace it? wala din power gains even if you do. only replace them kapag may sira na sya.
    Aug 2007
    it depends sa brand pag splitfire mas mahal mga 3k ata, sa banawe marami 1.5k-2k pag mga di kilala na brand. napansin ko nga din nagpalit ako ng high tension wire, 5star yung brand 9.5mm parang wala naman nagbago sa takbo ng civic ko. nag-iba lang mas gumanda tingnan kasi color yellow..
    Quote Originally Posted by speedyfix View Post
    +1,000,000
    Dec 2007
    Sira n yung first cable ng tension wire tumatalon n yung kuryente kaya gusto ko n palitan... at sk balak ko rin magpaayos ng idling... Need ko malaman yung presyo para alam ko kung magkano aabutin para pagpunta ko dyan s inyo mr speedyfix maayos n lahat ng sira... Thanks
    Aug 2007
    Quote Originally Posted by carbreaker View Post
    sir, sa classified ng tsikot may binebenta na high tension wire under accessories section, 1.2k made in usa 10.9mm.. check out this link http://tsikot.yehey.com/classifieds/...ct/6362/cat/47
    yung pagkabit kahit ikaw na mag ang install madali lang naman yan.
    Don't use cheap wires. Either get OEM wires or higher-priced ones. The cheap Chinese wires have rubber boots that crack after just a few thousand kilometers.
    Dec 2007
    Bro pano ko malalaman n OEM yung tension wire n bibili ko at san po b maganda bumili? thanks
    OEM... straight from Honda. Costs more, but will last longer. Or you can specify Honda-branded wires.
    Dec 2007
    Maraming salamat bro bk pumunta n lng ako s honda... Yung mga honda branded wires san ako pwede makabili non bk mas mura...
    Sep 2006
    mga sir, nu ba mga indications na kailangan nang magpalit ng high tension wires? and any idea how much is the oem for 97 lancer EL?
    May 2007
    Quote Originally Posted by jazcker View Post
    Inspect any abnormal wear like cracked on the cable, corroded tip both end or your cable older than 5 years old.
    Nov 2003
    go to honda and buy it there imo. those are better quality than 80% of the aftermarket ht wires out there.
    if you wanna upgrade get ngk blue wires or the spoon ones pero mahal sila.
Help Tension Wire
