Results 1 to 10 of 22
- Mar 2017
- 12
August 30th, 2017 03:17 PM #1Madalas nyo bang makita ang ganitong klaseng corrosion?
Hindi lang sa Amaron nagkakaroon ng ganitong corrosion kahit ano pang brand nagkakaroon ng ganito.
Kung hindi magstart ang oto mo, tingnan mo muna kung may ganito ang terminal ng battery mo. Brush lang ang katapat nyan at tubig, brushin mo lng hanggang lumambot ang umido at mawala or maubos. Nakakabawas ng contact ang corrosion minsan wala talagang contact kapag sobrang kapal na. At minsan kelangan idismantle ang batt terminal para maalis ang corrosion sa palibot ng battery post.
Sana makatulong ito ng konti sa inyo guys.
Sent from my A37f using Tsikot Forums mobile app
- Oct 2009
- 2,271
August 31st, 2017 12:58 PM #2nagkakaroon ng ganyan pag maluwag na ung battery terminal at madalas nababasa ng tubig..kaya dapat palaging mahigpit ang batt terminal.
- May 2009
- 93
August 31st, 2017 05:55 PM #3
- 54,290
September 1st, 2017 12:09 AM #4
- Jan 2008
- 4,726
September 1st, 2017 12:37 AM #5Experience ko lang.. sa auv namin dati na panget electrical wiring ganyan lagi battery.. nag uumido.. nung ma re-wire yung auv namin nawala yan kahit na de tubig yung battery.. so duda ko may parasitic load yan "grounded" sa common terms or may loose somewhere kaya ganyan
September 1st, 2017 12:51 AM #6
Have you checked the Electricals on the vehicle? I had one case where some chemicals coke up just outside the battery fill holes after 1 year of normal operation (and appearance). but on mine, it was accompanied by Low-Battery so I checked the terminals and was having almost 0 resistance between + and - terminals which indicate a short somewhere. removed the fuses one by one, culprit was the door lamp - the red light on the driver/passanger door. Removed the fuse and Battery would function normally afterwards.
- Dec 2007
- 727
September 10th, 2017 11:48 PM #7It happens to my previous vehicles. A friend of mine told me that sometimes different materials used on battery terminals and wire termination can have the effect. When I switched to lead terminals, it never happened to me anymore.
HTH
Sent from my ASUS_Z012D using Tapatalk
- 54,290
September 11th, 2017 12:02 AM #8lead does not react with battery acid.
many years ago, lead was the metal of choice for battery cable terminal clamp metal. at that time kasi, battery technology was still not as good as today's, and neither was voltage regulator science. every battery would cause the non-lead terminal clamps to develop white deposits and loosen.
lead clamps do not do this. but because lead was soft, it deformed with time and got loose, and the resulting electrical connections got weak. we had to regularly service them terminals.
in response, manufacturers introduced the harder metal alloys like brass, copper, and others, which would oxidize naman, necessitating regular maintenance, cleaning and tightening.
it is only now, with better battery sealing, that non-lead clamps can last longer, without regular maintenance.
notice that even today, all our auto batteries still use lead for their battery terminal posts.Last edited by dr. d; September 11th, 2017 at 12:13 AM.
- Oct 2004
- 278
September 11th, 2017 09:39 PM #9Just make sure your battery terminal clamps are tight.
...and put some silicon grease (grease ha, not sealant).
- Feb 2014
- 2,711
September 11th, 2017 09:50 PM #10
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
