Results 1,741 to 1,750 of 2247
- Jul 2009
- 2,618
June 28th, 2020 09:40 PM #1741inggit ako sa 4yr average mo. ako ave. 2years mapa diesel suv or passenger sedan. sa use ko nga parang pareho lang lifespan sa amin ng excel at gold. kaya masaya ako sa amaron ngayon 4yrs na so for me sulit na sulit. ang di ko lang malimutan yun mega force na replacement battery noon araw ng civic vti namin. wala pang isang taon tigok na.
- Jun 2005
- 3,774
June 28th, 2020 10:10 PM #1742Practically everyday during the first 4-5 years. Ginagamit 1-2 kms per day, pampunta simbahan or hospital ng dad ko. So around 4x ginagamit per day pero very short trips.
Also hooked the battery to an inverter to power the lights and some electric fans nung nagbrownout ng matagal sa amin nung 2014.
Sent from my MI MAX 2 using Tapatalk
June 28th, 2020 10:20 PM #1743
Pareho pala kami ni sirkosero
7 yrs and 4 yrs
Amaron the best [emoji5]
- May 2017
- 2,099
June 28th, 2020 10:46 PM #1744
June 29th, 2020 08:16 AM #1745
- 52,732
June 29th, 2020 08:32 AM #1746
June 29th, 2020 08:46 AM #1747
Mine sort of "wept" a bit of electrolyte around the caps and the charge indicator during the first year. It's not dripping or anything.... more like there's a thin film of the substance around the places I mentioned. Though definitely not enough to spill to the side or onto the vehicle.
My guess was it was topped off a bit higher out of the factory.
I just regularly washed them off and dried it with paper towels. It's been dry since the last time I cleaned it last year.
June 29th, 2020 09:13 AM #1748
The Amaron I bought in 2014 for the Vios leaked and ate the positive terminal. The Amaron I bought in 2017 for the Mazda is still clean. Might be a bad early batch.
Sent from my SM-A605G using Tapatalk
- 52,732
June 29th, 2020 09:21 AM #1749back in my day,
the crack around the battery terminal was a very common occurence.
the battery makers believed this was due to overzealous folks, who would very aggressively work the battery clamp's bolts or hit the terminal for whatever reason, resulting in cracking of the casing around the terminal.
it may also be due to a very short battery cable and/or in-effective battery clamp, resulting to pulling of the cable on the terminal, whilst the car is running and vibrating, resulting to crack around the battery terminal.
i would think that after decades of such, the manufacturers would already have found a remedy for this... weakness of design..
June 29th, 2020 10:07 AM #1750
there's this youtube article, about a 2000s altis, that had a high rpm on cold start (2000+ daw),...
high idle RPM at engine start
