Results 1 to 2 of 2
    mga experts patulong naman po.yung altis ko po kasi umaandar cya pero namamatay din agad.may lumalabas check engine bago cya mag shutdown,so pina scan ko po ito po ang lumabas na code P1310 igniter circuit.tanong ko lang po kung san nakalagay un ang alam ko po kasi wala na siya igniter kasi individual coil na siya.sabi po nang nagdiagnose baka ecu daw,possible po ba na ecu ang sira?may kuryente naman po sa mga coil,ok din linya ng injector.altis 02 1.6 manual tranny nga po pala.may nakaencounter na po ba sa altis nila ganito?madali naman po cya mag start kaya lang shutdown din agad.please help thanks..
    engine code P1310 means #3 ignition coil is faulty , no igniter signal to the ECM
    procedure to fix :
    erase the code and start the car ,if p1310 comes back
    switch the #3 coil to let's say #1 coil ,erase the code again and start the car .
    if the code changes to p1300 ( coil # 1 problem) it's positive that the original #3 coil is faulty which is at # 1 now
    if the code remains the same ( p1310 ) , suspect the signal wire to the ECM or the ECM itself.
altis needs help
