Results 1 to 6 of 6
July 6th, 2004 07:56 PM #1
i was driving kanina sa katipunan tas nag flash ako ng hig beams sa isang kotse. biglang namatay yung stereo. tas nag-on ulit.
na weirdohan ako dun sa nangyari so nagflash ulit ako ng high beam. biglang nag zero yung speedometer at namatay yung stereo...
ginawa ko ulit ng pangatlong beses pero ndi na namatay yung speedometer at stereo. :whoa:
chineck ko yung battery ok pa naman. nag start pa naman sya.
ano kayang nangyari? ndi naman ako dumaan sa baha kanina...
BANNED BANNED BANNED
- 3,790
July 7th, 2004 11:11 AM #2me mumu sa oto mo!
seriously, it could a be contact sa alternator. Try to unplug the alternator contact (ung plug na merong 2 or 4 wires), clean the prongs (if you have a spray on contact cleaner mas madali) or maybe WD40 would help.
It could some loose contacts. The battery would only supply power enough to crank the starter pero when running, all other equipments are supplied by the alternator. So mukhang nahihigop ng light mo yung power minsan - signs of loose contacts or dirty contacts yung ganun because of high resistance.
HTH.
July 7th, 2004 09:23 PM #3
loose contact yan. nangyari sa akin yan nun kapapalit lang ng battery ko. pag nag power window ako baba ng 8volts yun voltage, kahit signal light bumababa pa rin.
July 16th, 2004 06:56 PM #5
sorry sobrang late ng reply.. ngayon lang nagkachance mag-internet.
tama kayo loose connection nga sa battery. umuwi kasi ako ng late nung sat dahil sa sunod-sunod na exams. tas pagdating ko sa kotse ayaw magstart. in-on ko yung cabin light tas ginalaw ko yung batt terminals. yun nga maluwag. hinigpitan ko na lang. salamat po sa inputs nyo!
- 259
July 17th, 2004 11:56 PM #6sasabihin ko nga sana may maluwag na connection kaya lang nasabi na nilang lahat.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
