Results 1 to 10 of 15
- Aug 2012
- 6
August 1st, 2012 12:03 PM #1I have 2011 Innova E, meron akong foglight and want to install it by DIY, tanong lang po kung meron bang abang na linya para sa foglight at abang na wire para sa switch sa may lower dashboard? Meron din po bang makukuhanan ng wiring diagram nito? Thanks.
August 1st, 2012 12:35 PM #2
Bro.,- ang OEM switch ng foglights ng Innova ay kasama sa mga switches ng park/head lights.....
Not sure with the newer models though.
16.5K:weathermanf3:
- Aug 2012
- 6
August 1st, 2012 01:06 PM #3
- Aug 2012
- 6
August 1st, 2012 05:18 PM #5since sabi kasi ni sir CVT kasama sa switch ng park light, hinahanap ko kasi baka meron nang abang na wire sa may bandang likod ng headlight para dun na i-connect direkta yung foglight. Tiningnan ko kasi sa fuse box sa engine, may sarili na syang fuse na 15A, kaya malamang meron na rin syang abang na wire.
- Jul 2010
- 165
August 2nd, 2012 02:50 PM #6Yung DLAA na foglights for toyota innova may kasama nang wiring, switch, fuse and relay. So installation na lang kailangan.
- Oct 2009
- 2,271
August 2nd, 2012 04:39 PM #7ang alam ko pag orig at sa casa binili ang foglamp complete set na..
relay switch at diagram wiring..
ikakabit nalang..
- Aug 2012
- 6
August 2nd, 2012 05:22 PM #8meron kayang pwedeng mag post or mag send through e-mail ng wiring diagram. Thanks
- Dec 2012
- 15
March 23rd, 2014 05:45 PM #9I'm also installing (DIY) fog light for my innova E 2012. There is already a pre-installed wiring. I'm hoping that someone have a wiring diagram of Innova to help me install the switch. I couldn't figure out where to tap. The switch has 3 wires. I think number 1 will be for 12V power supply, number 2 will be for ground (or negative) and number 3 will be to the relay. My problem is where to tap the 12V fog light power supply and relay.
April 5th, 2014 03:19 AM #10
^ Have you figured out how to connect the fog lamps? The relay will drive them.
