Quote Originally Posted by jodski View Post
Hmm.. dami mo na rin pala napagawa. Anyway start tayo basics ulit for isolation lang
The way i see it based lang sa description mo its possible na electrical issue or fuel related problem yan. Try mo muna the following
1) Check the high tension wires baka may isa dyan may tama na. A tester will do ang replace all na kung hindi pa napapalitan
htw replaced na po. working din yung original htw
2) Double check the distributor cap baka pud pud na
bagong palit na din po distributor and cap (2nd hand surplus)
3) Palagyan mo na ng grounding kit kahit i DIY mo na. I highly recommend you have this done
magkano po ang grounding kit ngayon?
4) Check the fuel filter baka madumi na
replaced last december 2013 na din po but will have it checked na din para sure
5) Do you use an air filter for the carb? Kapag wala that will cause na pwede magbara sa passages yung dumi. Kung meron naman and you already used the car for 20,000 + KMS then its due for replacement na
bagong palit din po last december 2013
6) When was the last time nagpalinis ka ng gas tank? This is optional naman kung wala ka napapansin na nakargahan ka ng may halong tubig
ito ang di ko pa po napapagawa. will have it checked na din
After doing this and hindi pa rin ok lets see kung ano pa pwede gawin later
many thanks po sir for the troubleshooting guidelines
