Results 1 to 6 of 6
    Mga Bossing,
    Please share nmn your knowledge about this problem sa oto ko. Corolla 97 A/T, bale kanina ayaw mag start at kelangan pa mag jumper para umandar sia. Ano kaya problema ng oto ko? I changed battery last month lang Motolite yung puti. Di ko sia ginamit for almost two days, then kanina ayaw na mag start. Bossing ano kaya ang problema.
    Check the wiring for any loads that doesn't turn off when you switch off the ignition.
    BTW, is the alternator working to spec?
    Apr 2005
    bring your ride to the nearest Motolite dealers, they offer a free check -up of your battery, alternator and wiring connection. if the battery is at fault they should be able to replaced it free of charged under their warranty.
    Quote Originally Posted by nickel68 View Post
    Mga Bossing,
    Maraming salamat sa info.
    Nov 2007
    pa check mo din ang starter mo sir baka solenoid or contact grounding related?
    Quote Originally Posted by hotwheels View Post
    If it was due to the "abnormal use" of the battery, then it will be charged to the owner of the vehicle....
    So, TS, what happened here?
    7303:soda:
About Battery
