Results 1 to 18 of 18
    Aug 2009
    Hi! Just want to ask for all the owners of 1.6LS Optra. What oil viscosity are you using? which is more suitable for our car, 10w-30 or 10w-40, and what brand? thanks
    Quote Originally Posted by weszt View Post
    IMO 10w-40 for N/A engines are too thick.
    better use 5w-30 on it and also for a better FC.
    I dont own an optra but I use Royal Purple 5w-30 on my 1zzfe Altis.
    Oct 2008
    Shell helix plus 10w-40 blue gray container
    Quote Originally Posted by projector View Post
    Semi Synth ba sir? How much ito ngayon?
    sir, ano po nakalagay o recommended sa manual? 5w-30, normally po ata sa mga cold countries, like canada or US, para di hard start.
    I use Motul h-tech 100 10w-40 .
    check your car's manual...
    Aug 2009
    in my manual it is stated to use 10-30W, but now im using 10-40w shell helix semi-synthetic blue container..
    Feb 2009
    weszt,
    the SAE (society of automobile engineers) viscosity index is 10W-30 or 10W-40 not 10-40W nor 10-30W. the "W" is for winter grade, you can disregard this if you are in the Peelipins as we do not have winter. what matters is the summer grade of 30 or 40, the higher the number is the thicker the oil but your MPG is a bit lower. the thinner oil on the other hand has better MPG but the engine will be a little bit noisier. use what is recommended by the factory. just make sure the API (american petroleum institute) is SJ or better for newer cars.
    jick
    Aug 2009
    balak ko mag pachange oil at 40K gusto ko sana castrol fully synthetic. mas ok daw ung castrol kaysa mobil 1 eh.
    mas ok siguro sa akin yung 10w-40 baka kasi masyadong thin yung oil pag 10w-30 yung gagamitin ko eh yung normal ambient temperature sa atin eh lagpas naman talaga ng 30 eh.
    Dati Castrol gamit ko kaya lang madaling magkaroon ng sludge ang makina ko pagbukas mo ng valve cover . Ngayon Motul Htech 10W40 fully synthetic at maganda at hindi nagkakaroon ng sludge at magaan sa makina at tumipid sa gasolina.
Recomended Oil Viscosity?
