Results 1 to 9 of 9
    Aug 2009
    Hi just want to put all the problems that we encountered since the day we bought our optra....
    Model/Year/Transmission/Odo:Optra/2006/Manual Transmission/40,000km
    Problem: ....
    Parts Changed:. .....
    Solution: ....
    Problem 1: i have a leaked in my transmission system (in the left front wheel) . Cannot find the drain for the transmission?
    Parts Changed: Oil seal ( for manual transmission ) cost 750pesos
    Solution: Changed the oil seal, manual transaxle fluid and gasket. Problem solved!
    Problem 2: Aircon Switch malfunctioning, aircon switch must always be switch on. If you switch it off the green light indicator will not function properly need to switch on several times.
    Parts changed: None ( switch price 8k pesos ) wooooo!!!
    Solution: Just on the control knob of the fan and dont switch off the switch.. i hope it will last that long.
    I read in some articles why the fuel pump of optra always failed its because the wiring in the left fender of the car gets wet thats why as time goes by the wiring will then be shorted.. so better sealed it. take a look on your left fender where the water goes in.
    I hope you can share all the problems you've encountered.
    Thanks
    Dec 2008
    Model/Year/Transmission/Odo:Optra/2007/Manual Transmission/47,000km
    Problem: Loosen Stabilizer Link
    Parts Changed:. Stabilizer Link - Have checked with my personal mechanic
    Solution: Replaced (cost is 1500 each plus labor) - good thing is, it was still under warranty.
    purchased dec 2009
    replaced RKU unit P9800
    (december 2009)
    replaced fuel pump P7000
    (february 2010)
    replaced auxiliary fan set p4500
    replaced themostat P1500
    repaired / remanufactured radiator P2800
    (august 2010)
    Aug 2009
    Quote Originally Posted by joseph_abri View Post
    purchased dec 2009
    (december 2009)
    (february 2010)
    (august 2010)
    wow 2 years pa lang po yung unit nyo? bakit wala na agad warranty?
    Model/Year/Transmission/Odo:Optra/2004/Auto Transmission/51K (nung binenta)
    Problem: Hard Starting after refueling.
    Part(s) Changed: Throttle Body Assy.
    Solution: Replaced Throttle Body Assy (Under Warranty)
    _______________________________________________
    Problem: Busted Horns
    Part(s) Changed: Horns
    Solution: Replaced OEM Horns (Under Warranty)
    Buti nalang sa 5 years of ownership yan lang ang naging problem namin.. aside from poor FC & High maintenance cost..
    Aug 2009
    * SG
    konti lang ng mga pinalitan ah? hindi tulad ng mga kwento nila na sira lagi. sa mga ibang cars po ba eh hindi naisisira?
    hinihintay ko nga masira yung fuel pump ko pero hanggang ngayon ok pa din naman.
    how much did you sell it?
OPTRA problems enountered!! Care to share?
