Results 1 to 10 of 13
- Oct 2005
- 15
July 4th, 2009 03:43 PM #1hi fellow optra owners,
where do you have your AC cleaned?
do you think ok lang dun sa mga AC shops sa tabi tabi? andami dito sa pasig kasi
problema ng aircon ko. sa simula malamig. mga after 30 minutes parang humihina yung hangin pero malamig pa din. pinadagdagan ko ng freon pero ganun pa din ang behavior. so i hope kelangan lang ng linis
sabi sa chevy pasig kanina. 24T daw yung linis. di ko alam kung ginag*g0 ako nung taga casa. may mga dapat daw palitan na mga pollen eklat. pero hindi ako kakagat dun.
thanks
July 4th, 2009 06:48 PM #2
There is no problem if you have your car air con serviced other than the casa, 24k for an air con cleaning? Wow talk about highway robbery, in a reputable air con shop your 5k will be even more than enough provided your cooling system is still operational.
- Mar 2009
- 4
July 5th, 2009 03:11 AM #3Sir, here are the parts w/c needs replacement for complete general service of your a/c system. Thermal expansion valve 2,200 + drier 1,700 + flushing agent 250 + HIGH QUALITY refrigerant 600 + inert gas 400 + labor 1,500. total mga 6,650.00 assuming no leak ang system nyo at walang problem compressor nyo. Pollen cabin filter 1,550.00 pwede nyo check sa ibang supplier baka mas mura. We do a/c service at factory standard procedure (one year warranty). No guessing of work (tutumbukin namin ang problem ng a/c nyo).
Backyard shop might give you headache if improper procedure done with your a/c system specially if incorrect charging of refrigerant or insufficient vacuum procedure. Hindi lalaming ng factory spec around 3 to 5deg. centigrade. You can email me in case you need my help jemsonabrigo*yahoo.com or jemsonabrigo*gmail.com.
- Oct 2005
- 15
July 5th, 2009 10:46 AM #4
August 16th, 2009 01:31 PM #5
hi preho tyo ng model 2007 optra 1.6LS ok naman aircon ko, pero baka this sept papalinis k n din pra mganda, kasi once a year mganda nalilnis yan... try mi contakin ung CEEJAY sa las pinas mdami n sila review n mgaganda at mura pa...sabihn member k ng tsikot...eto no 874-6003 malayo pero ok naman service...hehe sabi nila.. try ako dun magpalinis...kasi d p din nalilinis aircon ko..hehe
- Oct 2008
- 656
August 16th, 2009 01:41 PM #6pag aircon wag ka na magtipid pumunta ka na sa reliable ng naglilinis ng aircon recommend ko sa iyo ung mit air quezon ave. pag nilinis kac ang aircon madami proseso at ang daming parts na lilinisin, pag sa tabi tabi k lng nakatipid k nga kaso hndi naman lilinisin lahat
August 17th, 2009 09:56 PM #7
hehe linis lang po ang gagawin ndi palit ng mga parts... ang ung ceejay reputable sa buong las pinas... pupunta p ako sa qc pra magpalinis...
August 17th, 2009 11:23 PM #8
- May 2006
- 33
May 7th, 2010 01:41 AM #9pag napansin niyo mahina na ang aircon kahit number 2 na speed ng fan, palinis niyo na yan at tanggalin na yung filter. basta have the aircon cleaned on schedule. eto kahit number 1 lang malakas na ulit, kahit tanghaling tapat na dati di kaya ng number 2 or 3 now kaya na ng number 1.
hope this helps anyone na mapapadaan sa tsikot forums.
- Mar 2009
- 100
May 7th, 2010 01:07 PM #10
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
