Results 1 to 5 of 5
- Sep 2008
- 4
September 6th, 2008 10:22 AM #1gusto ko sanang ma minimize o ma lessen road noise.... ano kaya magandang gawin.
September 6th, 2008 12:46 PM #2
sir try ninyo po pa deaden iyung flooring ng auto ninyo if for road noise, mababawasan po. try ninyo rin po search typing - "car sound damping, car sound deadening"
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 6th, 2008 04:30 PM #3Ano ba kotse mo?
Madaming options, depende sa budget and sa gusto mo.
Cheapest will be to use flashband. Its a roof sealer sold in hardware stores. The biggest roll (its like a tape) is around 600 pesos. No idea how many rolls you will need. Do note that this is heavy. Specially if used on doors. Jeff tan of Araneta Car Accessories uses this. I think (not sure) he charges around 1800 for a pair of doors.
In the Avanza forum, one guy used roof insulation on his roof and doors. He said it works. Cheap and available in hardware stores.
There are branded sound deadening materials that sound system installers use. Most are butyl or asphalt based. Comes in liquid form or sheets. Common brand is Dynamat, about 900 pesos for a sheet plus labor. Try the Ryan Audio showroom in Banawe. Look for Tim. Similar items are Wurth, Cascade, etc...
You can also try Candyshop in Banawe look for Bart. This guy does amazing work.
Vibrasystem is also good. Best thing about it is its lightweight. Thsi is what I used on my doors. http://www.g-audioph.com/vibra.html It comes in a box of 20 tiles. Enough for a whole car. I think its 4800 a box. Just add vibramats ground series for the floor. About 800 per sheet, forgot how big. They also have block series for doors. Around 1200 a box good for 2 doors with left over. Look for Gerry sa G Audio.
You can also try undercoat your car. Might help.
Good luck. You can tell Tim, Bart or Gerry that you were refered by Jun.Last edited by userfriendly; September 6th, 2008 at 04:40 PM.
- Sep 2008
- 4
September 6th, 2008 06:46 PM #4chevrolet captiva po... pwede pala ung roof insulation..taga iloilo po kasi ako cge po salamat sa suggestions i'll inquire sa mga car audio installers didto kng meron sila ng mga minention nyo... undercoated na po pero may road noise pa rin e. anyways thanks ulit sir.
- Sep 2008
- 4
September 6th, 2008 06:52 PM #5nakita ko nga sa ace hardware may spray can na pang deadening effective kaya yun?? ..almost P600..per can parang isang dangkal lng ang taas e..baka abutin 10 cans or more magamit tas hindi naman effective naku patay ako nyan...
Traffic!
