Results 1 to 13 of 13
    Oct 2005
    hi fellow optra owners,
    where do you have your AC cleaned?
    do you think ok lang dun sa mga AC shops sa tabi tabi? andami dito sa pasig kasi
    problema ng aircon ko. sa simula malamig. mga after 30 minutes parang humihina yung hangin pero malamig pa din. pinadagdagan ko ng freon pero ganun pa din ang behavior. so i hope kelangan lang ng linis
    sabi sa chevy pasig kanina. 24T daw yung linis. di ko alam kung ginag*g0 ako nung taga casa. may mga dapat daw palitan na mga pollen eklat. pero hindi ako kakagat dun.
    thanks
    Nov 2007
    There is no problem if you have your car air con serviced other than the casa, 24k for an air con cleaning? Wow talk about highway robbery, in a reputable air con shop your 5k will be even more than enough provided your cooling system is still operational.
    Sir, here are the parts w/c needs replacement for complete general service of your a/c system. Thermal expansion valve 2,200 + drier 1,700 + flushing agent 250 + HIGH QUALITY refrigerant 600 + inert gas 400 + labor 1,500. total mga 6,650.00 assuming no leak ang system nyo at walang problem compressor nyo. Pollen cabin filter 1,550.00 pwede nyo check sa ibang supplier baka mas mura. We do a/c service at factory standard procedure (one year warranty). No guessing of work (tutumbukin namin ang problem ng a/c nyo).
    Backyard shop might give you headache if improper procedure done with your a/c system specially if incorrect charging of refrigerant or insufficient vacuum procedure. Hindi lalaming ng factory spec around 3 to 5deg. centigrade. You can email me in case you need my help jemsonabrigo*yahoo.com or jemsonabrigo*gmail.com.
    Oct 2005
    Quote Originally Posted by jemsonabrigo View Post
    thanks for the detailed offer sir
    my optra is still under warranty pa so ibalik ko muna sa casa para macheck
    Aug 2009
    hi preho tyo ng model 2007 optra 1.6LS ok naman aircon ko, pero baka this sept papalinis k n din pra mganda, kasi once a year mganda nalilnis yan... try mi contakin ung CEEJAY sa las pinas mdami n sila review n mgaganda at mura pa...sabihn member k ng tsikot...eto no 874-6003 malayo pero ok naman service...hehe sabi nila.. try ako dun magpalinis...kasi d p din nalilinis aircon ko..hehe
    Oct 2008
    Quote Originally Posted by mastertsip View Post
    thanks
    pag aircon wag ka na magtipid pumunta ka na sa reliable ng naglilinis ng aircon recommend ko sa iyo ung mit air quezon ave. pag nilinis kac ang aircon madami proseso at ang daming parts na lilinisin, pag sa tabi tabi k lng nakatipid k nga kaso hndi naman lilinisin lahat
    Aug 2009
    hehe linis lang po ang gagawin ndi palit ng mga parts... ang ung ceejay reputable sa buong las pinas... pupunta p ako sa qc pra magpalinis...
    Quote Originally Posted by weszt View Post
    [SIZE="4"]REMINDER: do not post in SMS/TXT format when posting in tsikot.com forums.
    Read the RULES located at the top of every subforum.
    [/SIZE]
    pag napansin niyo mahina na ang aircon kahit number 2 na speed ng fan, palinis niyo na yan at tanggalin na yung filter. basta have the aircon cleaned on schedule. eto kahit number 1 lang malakas na ulit, kahit tanghaling tapat na dati di kaya ng number 2 or 3 now kaya na ng number 1.
    hope this helps anyone na mapapadaan sa tsikot forums.
    Quote Originally Posted by radeon View Post
    if you have cleaned your filters, etc. and still persist, there might be a problem with your air compressor. (air compressor should also be serviced by changing its oil, ask any AC shops who are well verse in chevrolet AC systems)
optra 07 aircon cleaning
