guys, have you tried replacing an optra parking lamp in the passenger side (right side) without actually removing the entire headlight?
i googled around and saw the following
http://wiki.answers.com/Q/How_do_you...05_chevy_Optra
On the passenger's side, simply, remove the air filter canister. You will need to use a 11 mm wrench or a 10mm. Don't try to take out the headlamp. Yo're gonna have plenty of room to change the bulb.
http://wiki.answers.com/Q/How_do_you..._a_Chevy_Optra
under the hood behind the headlight itself there is like a black round cap just turn it to expose the bulb there you will find a wire like clip just push the wire clip the bulb should release
