Results 1 to 2 of 2
    Oct 2005
    guys, have you tried replacing an optra parking lamp in the passenger side (right side) without actually removing the entire headlight?
    i googled around and saw the following
    http://wiki.answers.com/Q/How_do_you...05_chevy_Optra
    On the passenger's side, simply, remove the air filter canister. You will need to use a 11 mm wrench or a 10mm. Don't try to take out the headlamp. Yo're gonna have plenty of room to change the bulb.
    http://wiki.answers.com/Q/How_do_you..._a_Chevy_Optra
    under the hood behind the headlight itself there is like a black round cap just turn it to expose the bulb there you will find a wire like clip just push the wire clip the bulb should release
    Quote Originally Posted by mastertsip View Post
    actually sir,its easy to remove the headlight assembly ,just remove the two nut screw on top, and you have one on the inner portion ,near the radiator, then your done pull it towards you,then your done ,you will see the rubbber cover of the headlight socket all in one ,the headlight bulb and the parklight bulb socket.
how to replace an optra parking lamp?
