Results 1 to 20 of 33
    Dec 2011
    sa lahat po ng may optra 2006 model...tanong lang po may nabili kc kami last month...may talsik ba talaga sa deep stick sa engine nya/?thank po
    Jun 2011
    saan po location nyo sir?
    we do overhaul po at complete overhaul ng optra. LS/LT
    pwede rin po kami home service po.
    pwede ko po kayo qoute on the spot pag makita ko yung oto,
    09164709860
    544-17-14
    May 2011
    whoa! easy wielding the "overhaul" idea. check the basics first. it might be just a stuck pcv valve. have a compression test, engine cranking vacuum and engine idling vacuum test and a cylinder leakage test done first. the optra model is only a few years old and maybe the mileage does not even warrant an overhaul.
    Dec 2011
    sabi ni mang mario...normal lang daw sa mga optra un...?
    Dec 2011
    at 37k palang tinakbo..ok naman..wala naman check engine,,,run smooth...kaya lang bakit may talsik sa deep stick?
    Oct 2011
    ano ung talsik sa dipstick?
    Feb 2012
    un optrals 2004 ko ng eengine stalling xa hbang ngddrive ko,,nung pina diagnose ko s casa sbi my sira sa throttle body or my be s fuel pump,, tnong ko lng po,,san ko pde mkabili n mas cheaper compare to the casa? ksi s casa halos 16k sya thanks
    Jun 2011
    Quote Originally Posted by bob_dol View Post
    dalin mo muna samin sir reset muna natin bagonatin hatulan.
    *bob-dol
    pagka throttle-body ang me sira at palitin na eh wala kang pedeng pagbilhan niyan kundi casa.
    sa quezon ave, parts hanapin mo si Dave, nakakuha ko sa kanya ng 11k worth throttle (bnew).
    pagka-pinalinis mo yung throttle, malilinis lang yung lagusan pero ang nasisira ay yung mismong part
    ng throttle na me black covering (na me carbon sa loob) na mahirap ayusin yun, di basta-basta.
    wag mong pabayaan, delikado yan. I have experience the same namatayan ako ng engine sa u-turn
    at mahirap lalo na pagdi ka ready kase magla-lock yung steering wheel at no breaks ka... buti kung
    mabagal ka at malakas battery mo at kung maiisipan mo agad mag-start ng engine... so phrone yan.
    obserbahan mo, yung rpm mo unstable din pagnaka-idle lalo na pag-gapang sa traffic at naka a/c ka.
    ilan naba tinatakbo ng optra mo? kase yung 2004 optra LS ko is at 100k mileage nung magpalit ako ng
    throttle-body.... last january 2012 lang.
    call Mario in case * 09187801507
    good luck.
    tnx for the reply mga boss.......buti di mahilig sa AC si misis...soon papacheck ko na rin ang optra ....
    Aug 2009
    tama pa diagnose mo, ung skin pinaddiaognose ko 55km optra 06 din sira n pala high tension wire palit. nagpalit m din ako ng coil. kc pasira n din.
    Posted via Tsikot Mobile App
    Nov 2014
    mostly alagaan lang tlaga ang optra i have mine optra 2009, so far as long as alaga sa langis at air filter wala ako nagiging problema, note lang lagi nyo icheck ang transmission fluid sa mga AT, at yun ang mostly sisirain sa optra based sa mga complaints na naririnig ko
optra?
