Page 1 of 5 12345 LastLast
Results 1 to 20 of 152
    Feb 2017
    Hello Everyone,
    I'm kinda new to the forum and I'm a foreigner, so please forgive me if I'm gonna post in English .
    I have a Trailblazer 2014 LTZ and willing to do the regular maintenance outside the CASA. It has 25K on it's Odometer.
    1- Will it be safe to use ZIC X7 Diesel Engine Oil instead of Dexos2? I'm gonna use a 5W-30 as the Owner Manual suggests.
    2- I think it's also time for an ATF change, saw some MAG1 DEXERON-VI and I wanna give it a try, is it okay or I better go with the OEM ACDeldo Dexeron-VI?
    3- Do we have a Pane somewhere where we can drop, clean and change the ATF filter and place a new gasket or is it a sealed system? If yes, where can I buy these filters please? I'm looking for a complete flush since the shifting is kinda sluggish, wanna remove all in the torque converter as well as the line cooler.
    4- For the Engine Coolant, what brand do you recommend and where to buy it? Or do you suggest I go OEM?
    5- Does the 2014 TB have a DPF or just the simple EGR? Can't find any mention about it in the Owner Manual. Asked also the CASA if it has an EGR and if we can clean it and they were all clueless.
    6- Drive Belt and Timing Belt. I'm willing to change these 2 as well because it's not worth the risk, I wish we got chains but fact is a fact. Does anyone know a good chevrolet shop where I can do the job correctly? Fronte was hesitating since the car is kinda new to them. Also any idea about the labor cost?
    7- Transfer case 4x4 Oil. Even though I didn't do any offroading. Owner Manual suggests at 80K interval or 40K severe condition.
    8- Car is kinda new. Do you suggest an under chassis inspection? Where to do it?
    9- How to reset the Change Oil Reminder on the Dashboard?
    Thanks in advance guys .
    1. If that zic oil meets acea c3 requirements then yes. It's should be written on the bottle. (Htts 3.5 and above)
    2. I use dex6 on my torque converter. Mag1 is an ok brand in the US.
    3. No need to open the pan. You can however do a full drain from shops with a transtech equipment.
    4. Engine coolant stick with oem.
    5. Most likely no dpf. Egr cleaning can be done by shops listed
    6. Shops can do this. I'll list below
    7. Follow 40k
    8. Underchasis nut and bolt tightening.
    9. No idea
    Shops to consider
    Zix performance fb available
    Servitek full service
    Powertorq fb available
    Feb 2017
    Thanks a lot StockEngine, that was highly appreciated mate .
    Oct 2018
    [/INDENT]
    7. Follow 40k
    9. No idea
    Shops to consider
    [INDENT]
    HELPPPPP!!!
    Hi! I’m new to this forum and hope to get great advice here
    I’m planning to have a major (50k) PMS for 2014 AT Trailblazer outside CASA. Do you have any recommendation for maintenance shops who specializes in TB near Makati/Pasay/Taguig area?
    My husband is out of the country and am kinda scared to be ripped off by the shops because I know nothing about cars! Have called the usual casa we go to, but the PMS cost estimate is a whopping Php60k!!! Timing belts etc have to be replaced and all, but am wondering where to get less expensive but trusty PMS as well as where to buy the parts.
    Also, can anyone let me know what’s usually done/replaced for this kind of major PMS?
    Thanks in advance!
    Dec 2017
    Quote Originally Posted by RNIQQQ View Post
    [/INDENT]
    [INDENT]
    HELPPPPP!!!
    Thanks in advance!
    I thought this Trailblazer is timing chain instead of timing belt...
    If I may suggest, use the belt from casa. You can try to ask if you can buy from them and have someone else replace it.
    For your other question, you can check the Owner's Manual for the specific things that will be done for the PMS.
    Let us wait for the experts here to answer the rest of your questions.
    I hope you can post the picture of the quotation of casa.
    Oct 2018
    Thanks for the reply Archerfish. I’m supposed to bring it to CASA tomorrow for the check and get the quotation; will share it here once available
    Seconding Archerfish. Never had a PMS cost 50K before unless may major repair.
    Itemized quotation is necessary so we can remove the unecessary ones. I'm guessing may naisingit na aircon cleaning diyan for 20k or something.
    Apr 2017
    Quote Originally Posted by shadyanderson09 View Post
    Hello Everyone,
    Hi Sir, mind if I ask where did you get your ATF and Timing belt from?
    Quote Originally Posted by andrukit View Post
    look for dexron vi... mag1 and and mitasu have affordable ones acehardware or authorized resellers on fb.
    Mar 2004
    Hi.
    I have a 2015 Trailblazer LT and at 45000kms have issues in the front suspension area. according to a Previous Chevy mechanic, the bushings for the shock absorbers are being recalled and they (chevy) have a "campaign". (his term) and will replace the parts. Is this true>=? how do you go about this?
    Are there any more parts that are being recalled?
    thanks very much
    cranston
    Hello Everyone,
    am not sure if you have completed your PMS
    1. should be OK
    2. just ensure it's dexron VI
    3. what casa does is just drain it. always buy my chevy parts at Thunder Automotive - Banawe/Binondo
    4. AC/DELCO (available at Thunder...)
    5. no need for cleaning as per casa technician. they just scan/clean my EGR sensor when i got a fault shown on my dashboard
    6. changed mine at 90+K ODO. casa has a special tool to set into its timing to factory setting. suggest to buy all belts and pulleys/pump at Thunder and let them change it for you.
    7. done my all oil change at 40k ODO reading
    8. not necessary
    9. depress the gas pedal 3x within within 5 sec at ON (switch) position.
    Sep 2014
    Hello Everyone,
    5W-30 try mo Motorcraft dyan. swabeng-swabe ang Ford 5W-30 FS.
    coolant - basta kulay greenish yellow, mag Prestone ka nalang, pero dapat talaga specify ethylene glycenol ba yun
    yun AT fluid and Trasnfer case fluid, wag na noh. 25k pa lang oto mo. kalokohan yun CASA periodic maintenance na yun.
    Drive belt siguro palitan mo pero I doubt kasi 25k pa lang oto mo. pero lam mo na dito sa tin, lumulutong goma. depende lagi ka ba nakapark out of shade.
    Timing belt, wag na muna. 25k pa yan saka 2014. timing belt pang 50K or 7 years. actually nga dapat pag 80K yan
    EGR. i takbo mo na lang hanggang TPLEX and back. Italian tuneup, de-carbonized na yan
    for under chassis checkup, sa shell or sa bridgestone. they're honest tip ka na din sa mechanic para smile sya
    OB, he's a foreigner.
    Sent from my SM-T705 using Tapatalk
    Sep 2014
    ganun ba , eh paalis na ako for our dinner meet. wala kaya sya pinay wife or something, baka ma-translate. hindi kaya asawa ni solenn yan, alam ko naka Chevy mga yun eh
    If you have a warranty claim with GM and TCCI found out from you service records that you are not using dexos2 then you'll be challenged claiming the warranty.
    avoid that scene by sticking to dexos2 while within the 5yr warrenty.
    Some of the GM dexos2 certified oils are in the market for quiet some time, they are hard to find and expensive..
    ACDelco 5W30 retails around P550/litre
    Liqui Molly Toptec 4605 5W30 retails around 900+/L
    Motul 8100 & specific dexos2
    Mitasu MJ111
    MobilSuper3000 5W30
    GM Dexos2 are basically repacked Mobil oils
    There are also some re-packed casa oils claiming to be dexos2, forgot the brand..
    Jun 2018
    I am new here. Compared to Montero and Fortuner, is the availabilty of parts and price OK for a second hand trailblazer 2013-2014ish? Thank you.
    Feb 2017
    Quote Originally Posted by NewMD View Post
    I had lots of Fortuners and Monteros, almost all generations. Price and availability and reliability is the same, I even favor the TB in lots of aspects compared to the other 2 brands, you will have to dive into the experience by yourself to judge mate.
    Dec 2017
    I just realized, the guy may no longer be here as he made the inquiry last February 2017.
    I didn't even notice the date.[emoji38]
    Dec 2017
    I was smiling when I was reading the answer of *minicarph then you pointed out that he's a foreigner. Just now I noticed the date.
Chevrolet Trailblazer Maintenance...
