May alam ba kyo san makakakuha ng murang radiator ng Optra 04? d na kc kyang i repair... Thanks
text mo si Mario, madaming alam na pagkukunan siya at sa kanya mo na rin pagawa
yung pagpapalit. (Bakit di na mare-repair? me butas naba? na-try mo ba sa mga radiator expert?)
Mario 0918-7801507.
May butas, tinapalan na ng marine epoxy.. may tagas pa din.. cge po ,txt ko c mario..salamat..
Question: Bkit pag na ka bukas A/C humuhina ung tagas? Curious lng ako... Thanks
I bought a replacement radiator for my 2004 LS Optra last summer. My original radiator already showed signs of fluid loss on the side. So I thought I would do preventive maintenance and just replaced it. Anyway I ordered mine from ATCO in Las Pinas. Cost me around P7,500. FYI my optra is the is automatic so the radiator has a portion that cools the transmission fluid. Not a big deal to fix. Just makes getting the whole process of replacement longer since you have more tubes to take care of. Good Luck.
Mga sir,
anu gamit nyong coolant?may marerecommend ba kau?
Thank you.
If you're really into changing your coolant. DO NOT forget to drain them all
before re-filling with a new brand of coolant (coolguard in shell station).
