Results 1 to 13 of 13
    my 2015 tbz right brake light got busted.. medyo bad trip since a little over a year pa lang yung unit..
    whats great was that the onboard computer identified the problem and gave a warning! high tech na talaga ang mga auto ngayon...
    i checked sa banawe at tamang tama may ibang transaksyon ako on a different unit... di daw standard ang brake light ng mga auto.. may tinuro sila daw somewhere along shaw blvd na may chevy parts daw.. saan kaya yun?
    pwede naman i diy ito basta makabili lang ng pyesa sa labas...
    Feb 2009
    Quote Originally Posted by wowiesy View Post
    true, the time of the "mechanic" has passed. it is high tech now. it's not high mechanical. but check the basics first
    Bro mine was replaced by my suking electrical shop.
    Check first to confirm if your brake light bulb is busted. Kasi pwedeng lost contact due to rust scales formation. Ganyan ang nangyari sa akin noon before eventually the bulb get busted.
    Jul 2013
    care to post a pic of the busted bulb?
    maybe it has an LED brakelight.
    Jun 2018
    Yes ganyan talaga trailblazer parang low quality kasi sa aking binili ko june 2106 3months palang dead na ung breaklight pero lost contact lng pala kasi ung bulb socket nia mahina ung center contact madali lng ma bend,
    pero ngaun ung problem ko sa trailblazer ung steering mejo mabigat cia manuever pa feedback naman kung meron din naka experience nang ganyan
    Quote Originally Posted by Nils View Post
    Sir, eletric power na po ba ang tbz? Or If hydraulic meron yata repair kit nabibili... sana makatulong...
    had experience this before but mine is the hydraulic type PS.
    loose drive belt might be one of the culprit here. my tbz starter clutch pulley was broken that leads to the loosening of the drive belt and this is serious kung hindi mo maagapan.
    better get casa to check ASAP. good thing yours is still under warranty.
    Jul 2004
    Does your Trailblazer come with the LED Brake Light or the Bulb type? Locally they released 2 types.
    I think only the LTZ variants use LEDs.
    If it's bulb type, then it should be easy to replace, most likely it's just a double contact wedge bulb.
    It it's LED, check with your dealer if they can replace it for free. LEDs should last the lifetime of the
    car but I've noticed that the Trailblazer LED brake lights seem to be low quality
    Anybody here had completed his 60k PMS? Pinalitan nyo ba ang belt ng tbz nyo kasama mga idler pulleys, water pump, etc.? Sabi ng casa ay whole set daw pag nagpalit ng belt? Ang price quote nila sa akin ay nasa 30k!
    Jul 2015
    Any updates? may nagpalit na ba ng LED brake lights sa inyo? busted na rin sa akin(1 dot LED). palit buong panel or yung isa lang?
    Have you asked other dealerships? Usually if you replace waterpumps pag 150k or above, 60k is too early
    Iisa kasi ang chev casa dito sa norte bro, sa dagupan lang. But already done canvassing from thunder kung magkano ang presyo bawat isa sa set na sinasabi ng casa. Malamang yung idler pulleys lang siguro ang isasama kong palitan pag nagpalit ako ng drive belt ni tbz.
    yung brake / tail lights pala ng tbz ko ay pinasok ng rain water. casa says it is covered by warranty but there's a sealing quality concern here. Biruin mo yung isang brake light housing lang ang hindi pinasok ng tubig ulan. Had done dismantling the right side brake light assembly this morning to drain the water and temporarily sealed off the crevice to prevent further water ingress while waiting for the ordered replacement. Meron din bang naka experience nito?
    Feb 2017
    Never heard of LED getting busted that early.
2015 TBZ  brake light busted
