Results 1 to 10 of 13
- Nov 2002
- 1,326
July 16th, 2016 08:03 PM #1my 2015 tbz right brake light got busted.. medyo bad trip since a little over a year pa lang yung unit..
whats great was that the onboard computer identified the problem and gave a warning! high tech na talaga ang mga auto ngayon...
i checked sa banawe at tamang tama may ibang transaksyon ako on a different unit... di daw standard ang brake light ng mga auto.. may tinuro sila daw somewhere along shaw blvd na may chevy parts daw.. saan kaya yun?
pwede naman i diy ito basta makabili lang ng pyesa sa labas...
July 16th, 2016 08:26 PM #2
July 19th, 2016 02:29 PM #3
Bro mine was replaced by my suking electrical shop.
Check first to confirm if your brake light bulb is busted. Kasi pwedeng lost contact due to rust scales formation. Ganyan ang nangyari sa akin noon before eventually the bulb get busted.
- Jul 2013
- 2,450
July 19th, 2016 02:51 PM #4care to post a pic of the busted bulb?
maybe it has an LED brakelight.Last edited by Lew_Alcindor; July 19th, 2016 at 02:56 PM.
Tsikot Member Rank 3
- Jul 2004
- 1,540
July 19th, 2016 03:07 PM #5
Does your Trailblazer come with the LED Brake Light or the Bulb type? Locally they released 2 types.
I think only the LTZ variants use LEDs.
If it's bulb type, then it should be easy to replace, most likely it's just a double contact wedge bulb.
It it's LED, check with your dealer if they can replace it for free. LEDs should last the lifetime of the
car but I've noticed that the Trailblazer LED brake lights seem to be low quality
July 21st, 2016 04:34 AM #6
Anybody here had completed his 60k PMS? Pinalitan nyo ba ang belt ng tbz nyo kasama mga idler pulleys, water pump, etc.? Sabi ng casa ay whole set daw pag nagpalit ng belt? Ang price quote nila sa akin ay nasa 30k!
- Jul 2015
- 15
August 21st, 2016 01:15 AM #7
August 21st, 2016 10:32 PM #9
Iisa kasi ang chev casa dito sa norte bro, sa dagupan lang. But already done canvassing from thunder kung magkano ang presyo bawat isa sa set na sinasabi ng casa. Malamang yung idler pulleys lang siguro ang isasama kong palitan pag nagpalit ako ng drive belt ni tbz.
yung brake / tail lights pala ng tbz ko ay pinasok ng rain water. casa says it is covered by warranty but there's a sealing quality concern here. Biruin mo yung isang brake light housing lang ang hindi pinasok ng tubig ulan. Had done dismantling the right side brake light assembly this morning to drain the water and temporarily sealed off the crevice to prevent further water ingress while waiting for the ordered replacement. Meron din bang naka experience nito?
Sent from my SM-N9005 using TapatalkLast edited by Gumusut_Amige; August 21st, 2016 at 10:46 PM.
- Feb 2017
- 37
Daming issue ng SU7:grin:
Xiaomi E-Car
