Results 1 to 10 of 29
- Nov 2002
- 1,326
June 17th, 2015 09:25 AM #1almost 2 weeks na sa amin yung trailblazer... pinaka na notice ko is yung tagtag.. ths is my first suv kaya dko alam kung ganito ba talaga pag suv...
when we took in the unit delivery.. the tire pressure was at 38 front 41 rear .. the sticker on the door only specifies 35 front and 38 rear...
on a l8ng drive to manaoag on the first week.. binawasan ko to 36 front and 37 rear... mas ok na pero ramdam pa rin tagtag...
now I think nasa 35 na sya lahat front and rear...
I dont wat to go lower na since almist 10% lower na yan sa recommended spec.. I dont want to have to go under inflated for too long which means mught have to upgrade shocks siguro... tama ba?
what can you guys recommend?
June 17th, 2015 09:35 AM #2
June 17th, 2015 11:59 AM #3
sir, fortuner and montero namin naka 32 all tires ordinary air ok naman yun ride hindi matagtag
yun strada ko naka nitrogen tapos 35 all tires, masmatagtag sya sa fortuner and montero na naka 32 psi + suv hehe
pero ang gaan idrive nun strada compare sa suv namin :D
- Apr 2008
- 4
August 19th, 2015 10:46 AM #4Same experience about sa tag tag. I did the same bawasan yung pressure even down to 30psi (although my unit has rim 20), it helped pero ramdam pa rin talga. Before I changed my mags and tire, the feel was the same. One thing I noticed is, if your car is fully loaded, the ride was superb.
August 19th, 2015 10:49 AM #5
bigger SUVs have stiff suspension compared to sedans kaya matagtag.... because they are built to carry.... the only SUV that I've ridden on na maganda ang ride are the expeds.
August 19th, 2015 10:59 AM #6
When I hauled a sack of rice on my TBZ, the ride improved. I'm thinking of permanently putting at the back a (cement) sack of sand already.
August 19th, 2015 10:38 PM #7
YuNg tb namin.. Napansin ko katagalan lumambot na suspension... Unlike Dati matigas talaga... Pero nag palit na din Ako NG shocks and coils...
August 19th, 2015 11:46 PM #8
Ganun talaga cguro pag SUV. Yung sa amin after 10k km. ok na yung suspension. unlike before very bumpy
August 23rd, 2015 04:55 PM #9
Hi Wowiesy,
Ganyan din po yng complaint ng misis ko ng makuha nya yng TB nya last august 8, nagbreak in sya papuntang batangas matagtag sya. din advise ko palit ng nitro. afterwards smooth napo yng takbo at magaan dalhin.
August 23rd, 2015 06:08 PM #10
ladder on frame suv, matagtag talaga compared sa sedan. pick up based kasi yan and designed for hauling heavy loads. so tama, lagyan mo 2 sakong bigas sa likod para gumanda ang ride, or palit ka ng shocks.
air is 78% nitrogen. well, maybe some butts are more sensitive than others
Thread was made nung 2018 pa po sir.
