Page 67 of 68 FirstFirst ... 1757636465666768 LastLast
Results 1,321 to 1,340 of 1357
    Aug 2015
    #1321
    thanks bro. yan din po plan ko 5k regular pms. computerize din po ba yng checking nila like ford?
    #1322
    Quote Originally Posted by jesqatar View Post
    your car will remind you about your PMS. di sila gumagamit ng computer pag walang diagnosis na gagawin.
    Aug 2015
    #1323
    Thanks Gumusut_Amige,
    I have a bad experience with ford service center. last time na pinaservice yng explorer, they have listed all the defects generated from computer report. lahat ba naman ng rotor disc and caliper set pinapalitan. pinasok lang namin kasi due na for service. now, ang sabi ng service man kailangan palitan ang rotor disc dahil daw may tama na at hindi narin pwedeng ireface dahil out of specs na. so my wife decided na saka na lang muna palitan once nakauwi nako from abroad.
    nahold si explorer kasi hindi na raw pwedeng ibyahe pauwi ng laguna at bakal to bakal na ang naglalapat. napursige si misis na papalitan ang brake shoe costing us about 26t para makauwi lang. nagbigay ng quotation si ford almost 150t yata if i'm not wrong for rotor disc and caliper set (front and rear) including brake shoe.
    after ng incident na yon hindi na kami nagpaservice sa casa. mas maganda pa ang service ng bridgestone in Paseo, Sta. Rosa. doon ko na rin nalaman sa kanila na wala naman palang problema sa rotor disc at caliper. only minor reface lang ok na ulit ang rotor disc. Ford service center is also setting the pms period at every 3k which is very unusual.
    Aug 2015
    #1324
    Oct 2005
    #1325
    Hello. Saan Nakaka bili ng MUDGUARDS? Inubos ng doggie namin ang 3 mudguards ni TB thank you
    Oct 2015
    #1326
    master im going to have my 10k pms of TrailB LT where did u buy your own engine oil, oil filter(incl O ring seal) and Pollen filters. and coolant. out side casa.
    Oct 2013
    #1327
    3k for PMS? Maybe 3k miles not 3k kms. Nevertheless thats too much.
    Aug 2015
    #1328
    double post
    #1329
    Where's the water reservoir for the rear washer?
    Jun 2013
    #1330
    Question, pano maaccess yung settings ng dashcam sa rearview mirror like changing date and time. Base sa search ko sa net may remote daw yung one button model. May nakasama ba sa inyo? TIA
    Jan 2016
    #1331
    Good pm mga sir, I was checking out a used 2014 trailblazer on sale sa 2nd hand cars market here in Manila. I was only able to check the unit from the outside since wala na yung tauhan on duty. I would like to ask for your opinion if the attached images denotes an oil leak sa rear differential? Or ganun talaga na may black/oil areas sa rear differential? I checked the ground where the car was parked and there was no oil drops present.
    Thank you!
    Attached Thumbnails Attached Thumbnails img_20160104_195339.jpg   img_20160104_195102.jpg   img_20160104_195151.jpg
    Oct 2013
    #1332
    hlo po, naghahanap din po ng trailblazer. for a second hand trailblazer, 2014 0r 2015 model with the new black and white plate, preferably white. paki pm po me. tnx tnx
    Jan 2016
    #1333
    Quote Originally Posted by nico7 View Post
    check the 2nd hand cars dealer near Ultra Pasig. that's where I found the TB on the above. It's also in OLX.
    Aug 2015
    #1334
    Hi guys, I'd like to ask how to reset the Trailblazer TPMS.
    The monitor is alerting and displaying 22psi but it's actually 35psi (checked with different gas stations).
    Any quick fix for this? The constant alert is getting annoying.
    Oct 2013
    #1335
    Quote Originally Posted by dna View Post
    thank you sir dna, i did contact the above mentioned TB thru the number indicated therein pero wala po aku mapiga na info tungkul sa car kaya d na aku nag interest na echeck yung unit. It would be nice sana kung taga Manila aku., antay na lng aku iba unit.
    Aug 2011
    #1336
    Hi guys! Would like to ask for a quick fix.
    My TB's rear door won't open. I tried several times pressing the open/close button of the remote (key) and the open/close button at the driver's side, still the door won't open today. Last night, the door still opened when I pulled out some baggages and even closed the door gently.
    Would highly appreciate your help guys as I still do not have time to go to casa. Thanks
    Mar 2013
    #1337
    Quote Originally Posted by allan302000 View Post
    Can you open it from the outside? If so then it's just the child lock switch that has been activated. You can deactivate it when you open the door by looking for the switch in the door panel metal portion.
    #1338
    AC specialty shop for TBZ may alam kayo? sobrang taga sa dealer 100K+ yung quotation sa kaibigan ko
    #1339
    ouch 100k! and is that just for regular PMS?
    #1340
    baka sa AC repair bro
2014 Chevrolet Trailblazer 4x2 AT
