Good am mga sirs, ask ko lang if you have contacts with growl Audio? planning to upgrade kasi. Thanks in advance.
^i didn't noticed this with my civic and innova. Si tbz kasi ang naging road warrior ko lately:D
Which is better for service / maintenance - Chevy Pasig or Chevy Makati?
Considering upgrading the TB LT's audio to HU VT CNE-6959-A 7" LCD. Appreciate any feedback.. thanks
Got the replied from growl audio philippines via fb, the android oem head unit package is php38,000.00, free installation.
Package includes the head unit, oem reverse cam, tv tuner, gps antenna, gps navi system, ipod and usb connector, user manual, stylus, remote control and plug & and play harness. Wifi dongle is included in the android oem head unit package. Additional php6,500 for a pair of headrest monitor.
Is it a good deal?
Is it a good deal?
Baket kaya wading depth 600mm sa australia for both colorado ltz and colorado7 ltz. Sa pinas 800mm.
Hi guys, new Trailblazer owner here. I'm loving the truck, pero yung suspension matagtag talaga yung sakin. Parang hindi naman ganito katagtag nung nag-test drive ako.
Ano kaya, may problem kaya itong unit ko? I tried lowering tire pressure to 32 pero wala parin.
1) One person suggested lowering tire pressure to 27-28 psi, also suggested nitro gas sa tires na 33psi.
2) I also read something before regarding tightening the stabilizer _________? (sorry i forgot the term!)
3) Or can it be possible ba na may problem yung unit ko?
Ano ba next move dito mga sir? Would really appreciate the tips and suggestions!
Hello Zix888,
I heard some Duramax2 engine got EGR code P0401 and sometimes go to Limp mode status after driving 800km or more with the EGR blanking? But Duramax first gen got the EGR code P0401 for short driving ex. 5kms or more. Im pretty sure that you are more expose to a lot of EGR blanking with different car models. Are there any instance that different CEL's aside from P0401 will appear for driving X amount of distance for Trailblazer? Well appreciate for your insights and sharing for any informations. Are you blocking the EGR cooler coolant pipe when blanking the EGR as well? Thanks a lot.
Hi guys,
5k kms PMS pa lang kami ngkaproblem na agad TB LT namin. Crankshaft dw, mg 3 weeks na sya sa casa(north edsa).
Does anyone here encountered the same problem?
Hello komachi122,
Any specific OBD2 scan fault code found for this issue? Can you provide more details on this crankshaft problem?..Thanks for sharing.
Trailblazer is a ladder frame or truck chassis kaya sigurado matagtag talaga yan katulad din ng ibang ladder frame suv brand(everest, fortuner, montero, mux). If you want carlike driving and comfort suv look for monocoque body/ chassis SUV
Hi Zix, how much does EGR blanking cost?
Did you read about this somewhere? I had one of our Pajeros blanked before and it was OK but then the Duramax engine is different from the 4M41. Hmm...
I'm not sure about OBD2 scan fault code, it says on the paper "crankshaft position sensor needs to replace".
Sounds bad for a trailblazer that is just a 5 months old and only 5k kms. Moreover, the crankshaft sensor is not available, they need to import it from thailand. We have been patiently waiting for our car to be fixed. This is the 3rd week of waiting game. Sigh!
Sounds bad for a trailblazer that is just a 5 months old and only 5k kms. Moreover, the crankshaft sensor is not available, they need to import it from thailand. We have been patiently waiting for our car to be fixed. This is the 3rd week of waiting game. Sigh!![]()
Hmmm. Quite alarming with that odometer. This time the 200hp car should be supported by after sales people.
Hello komachi122,
Thanks a lot for sharing on what's on the paper. There must be fault code equivalent for this "crankshaft position sensor".
Im assuming that you got rough idle? If you don't mind kindly share here if they can provide you the scan fault code for this. And pls ask them the part number of this crankshaft position sensor once they replace for future reference on this forum. Once again thanks a lot for sharing this information to us.
Yes and disappointing too. The performance was impressive. The power and torque were exciting until this problem occurred. After 5k kms PMS while I was cruising, the check engine light turned on and "Kumakadyot kadyot". We brought it to the casa on the next day, and that is the findings of the technician, crankshaft sensor position needs to replace.
