Results 1 to 11 of 11
    Aug 2011
    May alam ba kyo san makakakuha ng murang radiator ng Optra 04? d na kc kyang i repair... Thanks
    text mo si Mario, madaming alam na pagkukunan siya at sa kanya mo na rin pagawa
    yung pagpapalit. (Bakit di na mare-repair? me butas naba? na-try mo ba sa mga radiator expert?)
    Mario 0918-7801507.
    Aug 2011
    May butas, tinapalan na ng marine epoxy.. may tagas pa din.. cge po ,txt ko c mario..salamat..
    Aug 2011
    Question: Bkit pag na ka bukas A/C humuhina ung tagas? Curious lng ako... Thanks
    Feb 2005
    Quote Originally Posted by Niok View Post
    Sir, Saan kung malapit kayo sa Fermin Radiator Shop sa Sucat Paranaque, Dalhin niyo lang doon, Kayang gawin yan. Ito contact number, 775 2293, hanapin niyo lang si Domie.
    Jun 2007
    I bought a replacement radiator for my 2004 LS Optra last summer. My original radiator already showed signs of fluid loss on the side. So I thought I would do preventive maintenance and just replaced it. Anyway I ordered mine from ATCO in Las Pinas. Cost me around P7,500. FYI my optra is the is automatic so the radiator has a portion that cools the transmission fluid. Not a big deal to fix. Just makes getting the whole process of replacement longer since you have more tubes to take care of. Good Luck.
    Jan 2011
    Mga sir,
    anu gamit nyong coolant?may marerecommend ba kau?
    Thank you.
    any brand basta 50-50 ang mix... 50-coolat at 50 distilled water
    Jan 2011
    Quote Originally Posted by dndk2007 View Post
    Mga Sir,
    Ilang liters po sa coolant at water? anung brand po you recommend?
    TY.
    If you're really into changing your coolant. DO NOT forget to drain them all
    before re-filling with a new brand of coolant (coolguard in shell station).
Chev optra 04 - RADIATOR
