Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
    Aug 2009
    What brand and type of car fire extinguisher would you recommend? Primary purpose is of course to save the passengers. Secondary na lang yun i-save yun car.
    saw one at ACE brand is Palmer red and green container. The green one is more expensive than the red one. Any feedback about this brand o meron pa mas maganda na mas reliable. Thank you.
    Jun 2006
    If the green one is the HCFC 123 thats good for ABC type fires, then get that one. HCFC is supposed to be enviormentally friendly IIRC. Also, this type does not require clean up as its a gas that does not leave behind residue.
    The regular red type fie extinguisher uses a dry chemical that will wreak havoc on your electrical system and is a pain to clean up. Although if your car catches fire your electrical system is probably toast anyway. Its good for ABC type fires.
    Fire types are A = wood, paper, cloth type fires. B = oil and gas firesand C = electrical fires.
    I would suggest between a CO2/inert gas or a dry chemical fire extinguisher.
    For fires that are small or just starting, CO2 or inert gas fire extinguishers are effective enough.
    For bigger fires, no choice but to go for a dry chemical extinguisher to control the fire from spreading. Cleaning up the powder after the fire would be a bitch though.
    Vehicle fire extinguisers are designed as a means of escape and not really a means to save the vehicle (that's just a bonus).
    in Thailand, almost all the hiace that i saw has a fire extinguisher. maganda sana if meron dito with bracket na para naka install na din sa loob ng car
    Automotive fire extinguishers do come with a bracket when you buy them.
    Feb 2005
    +1.
    I have the Palmer Brand (Red) installed in my car, and it comes with a bracket, but no screws
    I bought mine (red) 3 years ago at ACE hardware.
    The level is still on 'good' or in green. Should I replace it na?
    BTW, the brand is Seire(?).
    Jun 2006
    i think chemical extisnguishers needs to be "shaked" once a year to prevent caking.
    Jan 2009
    Got this two years ago from Handyman, Trinoma.
Fire Extinguisher for Car: what brand and type would you recommend?
