I got a thinkware F770 for my CR-V 2018. Though pricey, I like this dashcam. The resolution is really nice but it eats up a lot of memory card space on the SD card. There's a parking mode that records any motion detected. There are also safety features like the Front Collision Warning and Lane Departure Warning.
Here are some notes on the installation of the thinkware F770:
To avoid soldering the hardwire kit on one of the fuse on the fuse box, I bought two fuse taps. For the CR-V 2018 (my car), the fuse used there is a low profile mini fuse. I got my fuse tap here:
3. Micro SD Card
The included 16GB on the thinkware F770 will only give 1 hour of continuous recording. It is recommended to buy a 64GB microSD card which will give you 8 hours of continuous recording if you are just using the front dashcam. Half if you're going to use the front and rear.
Thinkware is a bit picky when it comes to micro sd cards. I got lucky that I got the 64Gb Sandisk Ultra to work on the camera. However, Sandisk doesn't have any guarantees on using their ultra line on dashcams. I'm now looking to source a 128 gb sd card that works on the dashcam. Thinkware doesn't support 128 gb officially but there are reports that some 128gb micro sd cards work. Check out the link below for the micro SD cards that work with the Thinkware F770.
