Results 1 to 10 of 10
    I've been using a steering wheel lock for about 2 years now at nawala ko susi dito sa mall. Nagpunta ako sa handyman at sinabi ko yung problem, na kung pwede putulin yung lock kesa umuwi pa ako at kunin spare key, mas mahal pa fare pauwi. Ang sabi nung isang guy babarinahin lang daw yung susian para mabuksan. Pero ako sabi ko baka di mabuksan, bumili ako nung panglagari na blade.
    Nung binarena na nung lalaki yung susian, voila, nabuksan agad at nagloose. Walang 30 seconds. So how does this product protect our car again? Knowing na ganun lang pala siya kadali tanggalin.
    Its more of a deterrent really. If it will delay the carnapper, they will look for easier prey. What brand steering lock did you have? The cheap ones i saw before look pretty easy to defeat. What others do is to saw the steering wheel to remove the lock.
    Depende siguro sa steering lock na gamit mo. Meron mamahalin na di mo basta basta ma bubuksan maski barenahin mo pa. Im using steplock for my steering lock.
    Jan 2014
    dats korek. ngayon para mas safe oto mo lagyan mopa ng kadena yung sa gulong mo para mas safe para bago makarnap yaan siguro maalarma na paligid. for double security yaan kahet medyo time consuming lalo na kung mag mamadali ka, pero safe naman oto mo.
    Jul 2011
    Ung mga carnaper sa pinas naman siguro ay hindi mahilig magdala ng portable drill, pero swerte ka pa din at natangal ung wheel lock kesa ung manibela ang sisirain. Kung kaya pa naman ng budget mo pa install ka pa din ng car alarm or ung car gps tracker.
    Oct 2009
    kaya lang madali kasi naka bukas ung pinto mo..kaya ung safety lock lang prinoblema nyo..
    bubuksan ung pinto ng carnafer,babarenahin ung safetylock sa manibela,irerekta ung starter ,sisirain ung lock sa manibela..pano kung may alarm pa..
    Oct 2011
    deterrent lang talaga yan. matatalinong matsing din mga carnapper. they choose which to carnap.
    "Its more of a deterrent really. If it will delay the carnapper, they will look for easier prey" from sir vinj. +1
    in the olden days, before the advent of car alarms, some motorists would bring with them the hi tension cable. the one from the ignition coil to the distributor..
    ...sayyy... not a bad idea, even today..
Steering wheel lock
