Results 1 to 19 of 19
    Aug 2009
    Could i be flagged down because i have a "wang-wang" type of car alarm? it is your common car alarm but should i remove it? any replacements for that type?
    Jun 2006
    I'm not a lawyer, but from what I know, they can not just flag you down if you do not commit a traffic violation. In case there is a check point, the rule is "plain sight". So they can not force you to open your hood, glove box, trunk or car door if you do not want to. They can however, ask you to open your car. If you consent then plain sight is no longer valid since you gave them permission to check your car. If you do not agree to a physical check, they can only use flashlights to see thru your windows.
    Too be safe and to follow the rule of law, its best to remove your siren. I'm also in the same situation. My dad installed a wang wang when he was using the car. I dont use it but never removed it. Might as well remove it now.
    Feb 2007
    If it's a common car alarm then it is only engaged once you park your car. I don't see any reason why your car alarm would go haywire while you are driving.
    IMHO tanggalin mo na lang, di mo naman in reality kailangan yan.
    Jun 2009
    If the "wang-wang" came as standard equipment w/ the alarm, then I see no reason why it should be removed. IMO, the only time it's illegal is if it's activated while your car is moving through traffic.
    Puedeng material pala sa comedy ito. Someone breaks into your car. Alarm is activated, including wang-wang. Thief runs off w/ your valuables. Police rush to the scene. But instead of going after the thief, they arrest you for illegal use of wang-wang.
    Mas mainam na tanggalin mo na lang para wala kang abala iyong iba lalo na MMDA hindi naman nila alam na para sa alarm iyan .
    Aug 2009
    This is my car alarm that's installed. i've encircled the "wang-wang". should i tell my casa to replace this with something?
    Feb 2006
    Quote Originally Posted by bugmenot View Post
    based sa picture mo speaker lang ng alarm unit mo yan di naman wangwang ang wangwang kasi masmalaki ang magnet & malaki ang size ng body & ang control unit makikita mo may microphone pa pang public address system may selector switch din na may yelp, hi-lo, wail-1, wail-2, manual, siren, eto example ng siren or wangwang control unit
    http://www.globalsources.com/gsol/I/...1010787183.htm
Should i remove my "wang-wang" on my car alarm?
