Results 1 to 4 of 4
    Oct 2007
    Hi guys..
    just wonderin if some of you might know what is a "FUEL CUT-OFF Valve" and how to install such device for a vehicle security.... As I know if left closed
    engine will not run since theres no gas supply coming from the TANK, so once
    car-JAcked.. the culprits will get-away for a short distance and then BOOM-... no engine will stop no gas-flow..
    Problem is Im not sure if we have such device here in Philippines and where is
    the ideal secret place to place such valve.. and will it be, electronically controled or manually..
    If this is possible aside from having our normal CAR-ALARMs w/sirens i think this is also good and make sense..
    Hoping for someone to advice..
    cheers.
    Nov 2006
    You mean an immobilizer?
    Search for the magic word , it does not need to be that complicated.
    Oct 2007
    Quote Originally Posted by Taurus View Post
    Sensya na po.. wala pa kasi akong kotse nag gather lang ako ng
    info's if yu dont mind.. & for sure you've been like me a newbie once..
    unless you own a carshop or something..
    anyway thanks po..so direct help.
    cheers
type of Security System for your Vehicle?
