Results 1 to 16 of 16
    Jun 2013
    Is it normal for the parking sensor to continuously beep when it's raining? The sensors worked ever since i got my car a week ago. First time i drove it under heavy rain and the sensor has been continuously beeping. Should i have the sensors replaced?
    Apr 2005
    It's not normal, unless you put your gear in reverse and there are objects near your car.
    Oct 2011
    Continuos beeping is not normal not unless there is an objuect behind your car.
    Apr 2005
    Btw, ganyan nangyari nun nasira backup sensor ko ng Casa, non stop tunog pag nag reverse gear ako kahit wala naman object sa likod
    Sep 2006
    Shouldn't beep unless there's an object close by/obstruction.
    Jun 2010
    check mo yung sensor mismo baka natakpan ng putik or debris
    Oct 2011
    Also, have your sensor check first and see if need replacement.
    Mar 2011
    HI Sparton, the sensor probably was reacting to the amount of water that the sensor mistook as an object
    Try it when it is not raining. If it does not change then bring it to the dealer.
    Dec 2004
    multo lang yan, pa-bless mo tsikots mo
    Oct 2011
    baka kailangan din magpa dugo. lol.
    Jun 2013
    Quote Originally Posted by voaquino View Post
    Tried it again a couple of hours after siya nabasa. So far ganun pa rin. I read somewhere na hindi daw naka-seal ng maayos and basa pa rin sa likod ng sensor. Anyway, balik ko na lang sa casa. Iniisip ko pa kung ibabalik ko talaga since hindi ko masyadong kelangan ang rear sensor. Parang wala rin akong tiwala dun. Hehe
    Oct 2011
    ibalik mo na sir sayang din yan.... useful din kaya rear sensor.
    Jun 2013
    baka may iba pang masisira.. hehe.. pero sige, ibalik ko sa casa. salamat.
    Jun 2013
    iniisip ko rin magpakabit na lang ng avt HU with rear camera.. kaso mejo mahal sa casa.. d ako sure kung may mabibilhin nun sa labas na mas mura.
    Oct 2011
    punta ka lang sa banawe sir. ang dami dun.... try mo sa C3 audio
    Jun 2013
    ayus. balak ko bumili lang ng unit then pakabit sa casa para hindi ma-void ang warranty ng kotse ko. salamat.
Rain and rear parking sensor
