Results 1 to 10 of 10
- Jul 2006
- 145
September 6th, 2008 07:19 PM #1I have Honda City and I am experiencing keyless lock/unlock issues. Kasi hindi po nagreresponse yung locking mechanism ng door pag pinipindot ko yung lock and/or unlock sa remote. Pero naactivate naman po yung pinaka alarm pag nilock ko sa remote (pero di malolock yung pinto) then pag binuksan pinto tutunog at magiingay ang siren. Ano po kaya ang problem? Pwede po kaya itong i-DoItYourself? Ang alarm system ko po ay "CAR ALARM AM-681" honda naman po ang naka tatak sa remote control ko.
Hope you could help me with my problem....Thanks to all
September 6th, 2008 09:10 PM #2
kung gumagalaw ng konti yung lock pag pindot mo ng lock/unlock, e malamang sir actuator yan. ipa adjust mo na lang.
September 7th, 2008 10:20 AM #3
What is affected? isang door lang ba or the main lock/unlock system? most probably it's only the mechanical mechanism in the door lock, stuck up or loose. Kasi yung actuator di naman masisira nag ganun-ganun lang. Kung familiar ka sa mechanism, pwede mo i-DIY, pero kung hindi, dalhin mo na lang in any car shop. It won't take them 10 minutes to fix it.
September 7th, 2008 02:48 PM #4
Kung taga-Las Pinas City ka, dalhin mo sa shop ni caloy (tsikoteer) sa may unahan ng main gate ng PhilAmLife Village. Siguradong gawa kaagad iyan... Malamang ngiti lang ang bayad kung simpleng adjustment lang (baka mapa-softdrinks ka pa).....
6707:choir:
- Jul 2006
- 145
September 7th, 2008 07:14 PM #5Clarkent - ang affected ay yung lahat ng door.
Lexter - hard to tell if nagalaw pero nilagay ko tenga ko at dinikit sa mismong door, everytime i press lock/unlock sa remote eh may naririning akong sound like a rotor or something, basta me sound.Yap,familiar ako sa mechanical tingin ko kaya ko ma-figure out ito, ang problem ko is di ako marunong magkalas ng sidings ng Honda.Atsaka nakakatakot galawin kc slightly use ung car nasa 15Tkm pa lang.
CVT - taga cavite po ako madaling po ako mapagawi ng las pinas
My problem is intermittent talaga yung issue, kanina gumana na naman wala naman akong ginagawa..basta na lang gumana..hayyyyyyy i expect magloloko ulit ito...
September 7th, 2008 08:43 PM #6
with that info, the more i believe it is more of a mechanical issue. there's a small steel rod connecting yung lock lever sa actuator going to the latch. i think nag-loose yon and because it's loose, the actuator cant push the lever.
(i am speaking from experience, bro. same "symptoms" happened to me a few months back)
September 19th, 2008 05:03 PM #7
same problem with my ride. sa akin, yung sa driver side lang ang ayaw gumalaw. nagtanong ako sa isang maliit na shop banawe expert daw.... electrical daw ang problem, pinapupunta ako sa electrical shop, wiring daw ang diperensya.... ano kaya sa palagay nyo? please help naman po.
September 21st, 2008 07:42 PM #8
- Jul 2006
- 145
November 11th, 2008 08:20 PM #9update ko lang po kayo..nagloko na naman po yung door lock ko --> ayaw na naman ma-oprate using remote. Dinala ko na po sa Honda Cavite. Sira na daw po actuator. Pinalitan nila at i spent P750 sa actuator. Gumagana na ngayon...
- Dec 2008
- 3
December 10th, 2008 04:05 PM #10
Monk-owned R53
